3" dp flange on t3/t04e
Old Nov 20, 2003 | 08:17 PM
redboost10's Avatar
Default 3" dp flange on t3/t04e
has anyone welded a 3" dp righ to the dischage flange on a t3/t04e? is that flange wide enough? might be a dumb question but just wondering before i order my discharge flange
im just not sure if that flange is too small, will i have to weld on a 2" or 2.5" pipe first then flare it out to 3" or is the flange wide enough to just wled on the 3" pipe?
Modified by tgh99si at 5:35 AM 11/21/2003
Old Nov 20, 2003 | 09:26 PM
rioninja's Avatar
Default Re: 3" dp flange on t3/t04e (tgh99si)
Wont fit..
I used one of these 2.5-3" machined transitions from atpturbo.com:
I had to use allen bolts to secure the flange to the turbo though,
since there is 0 room for a wrench/socket after you weld the transition on.
Works perfect though, and looks great. (I have a 4bolt turbo).
Old Nov 20, 2003 | 09:28 PM
redboost10's Avatar
Default Re: 3" dp flange on t3/t04e (rioninja)
so 2.5" will fit, then it flares out to 3" it looks like? i have a 4 bolt discharge too
Old Nov 20, 2003 | 09:38 PM
rioninja's Avatar
Yep. But you pretty much have to use allen bolts to attach the flange to
the turbo. No big deal, since you can pick them up at the hardware store for cheap.
My setup is actually:
4bolt flange -> 2.5-3" transition -> v-band setup
Old Nov 20, 2003 | 09:42 PM
redboost10's Avatar
i would probably just weld 4bolt flange-transition-3"dp
awesome, thank you very much sir
Old Nov 21, 2003 | 12:41 AM
SiR Kid's Avatar
New User
I didn't order that one, but I have a 2.5" transition to 3" on mine to. It's a 1.5" transition, I believe from Burns Stainless... Works GREAT for room for the bolts.
Allen headed bolts sound like a great idea, too... I think I might pick some up when I go to Lowe's!
Old Nov 21, 2003 | 04:55 AM
baddassduramax's Avatar
Default Re: 3" dp flange on t3/t04e (SiR Kid)
i have a 3in welded to my 4bolt flange, was kind of a pain in the ***, using allen bolts, im gonna re-do it and go 2.5 flared to 3
Old Nov 21, 2003 | 05:12 AM
Overblown-Teg's Avatar
Default Re: 3" dp flange on t3/t04e (civicb18)
Any ideas where to get the Five bolt flange with a 2.75" or bigger hole in it? I got the one from atp and the whole is tiny.. I had to spend all sorts of time porting the thing just to make it close to the turbo outlet. For example I have the transition from ATP.. the transistion fits inside the turbine of my sc61. And the flange they sell with the transition needs about an 1/8" cut off each side just to line up right.
Old Nov 21, 2003 | 06:18 AM
quikB18B's Avatar
Default Re: 3" dp flange on t3/t04e (Overblown-Teg)
Double121 modified his revhard downpipe, to 3" with a/c, he bought a welder and hacked away. The drop/turn is real sharp though in order to clear ac compressor.
I just have a 2.5 that flares to 3"
Old Nov 21, 2003 | 06:48 AM
redboost10's Avatar
Default Re: 3" dp flange on t3/t04e (quikB18B)
thank you for all the info and help, i never knew about those transitions
Old Nov 30, 2003 | 06:45 PM
DubyaAye's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rioninja &raquo;</TD></TR><TR><TD CLASS="quote">Wont fit..
Works perfect though, and looks great. (I have a 4bolt turbo).</TD></TR></TABLE>do they also sells the flange too or just the transition?
Old Nov 30, 2003 | 07:18 PM
5thgencivic's Avatar
Default Re: 3" dp flange on t3/t04e (DubyaAye)
Mine is 3 inch welded right up to the flange. Some studs on the turbo will work. The pipe just has to be dented in a tad.
Old Nov 30, 2003 | 08:11 PM
D-Man's Avatar
You could alway make or get one of these from cheapturbo.com,it's a 3" V-Band clamp welded onto a bolt-on flange....or buy mine,its brand new,ill sell it for half the price I paid for it from cheapturbo cause im not using it,I going with a 4-bolt garrett...$85 shipped
Modified by D-Man at 9:20 AM 12/1/2003
Old Nov 30, 2003 | 08:45 PM
rjardy's Avatar
Default Re: 3" dp flange on t3/t04e (D-Man)
thats what I have, its full 3"
Rob
that-guy
Welding / Fabrication
Dec 29, 2010 10:15 AM
turbojeesx
Aug 11, 2008 03:58 PM
huepowered
Jun 8, 2006 04:22 AM
brent_G
Aug 22, 2005 01:55 PM
99silprelude
Aug 24, 2004 11:51 AM
