Manual - Auto Ecu Interchangable?
Old Nov 20, 2003 | 06:49 PM
Apollo's Avatar
Default Manual - Auto Ecu Interchangable?
I know that on some vehicles they are and i was wondering if their is any difference and what they are. Sorry if this is a repost.. i did a search and nothing.. Thx
Old Nov 20, 2003 | 07:00 PM
gumbii's Avatar
no...
Old Nov 20, 2003 | 09:55 PM
dohcnotec's Avatar
Default Re: Manual - Auto Ecu Interchangable? (Apollo)
Yes, they are. I gained 6 Hp and 2 lbs Torque when I switched from a p28 to a Accord ecu.
Old Nov 20, 2003 | 10:02 PM
mmuller's Avatar
Mad Scientist
Default Re: Manual - Auto Ecu Interchangable? (dohcnotec)
well, auto ecu's can be converted to 5 speed.
they are interchangeable, you'll get cel's and depending ecu you'll get a lower redline. Why would you want to put a auto ecu in a manual car or viceversa?
Old Nov 24, 2003 | 05:47 PM
Apollo's Avatar
Just wondering, thanks for the information tho. You can always chip them tho cant you? ahh not a big deal, i was just wondering, thx
Old Nov 24, 2003 | 06:21 PM
Kendall's Avatar
I would just assume tune the stock one via Hondata, VAFC, Field, etc. Or go with a standalone engine management system.
Theoretically all you are doing is changine a few basic engine functions when you change an ecu so why not change them yourself to optimize what you have rather than using something that was designed to run something else. Also, if you have the ability to tune the ecu, then every time you modify the car, you can further tune the car to work with each additional modification.
Old Nov 25, 2003 | 09:09 AM
doublejz's Avatar
Default Re: (dc231)
you can use a auto in a man car you will have a cel, but will run. you can't use it the other way around, unless you get it chipped to convert it to a man. autos have lower rev limits too
akouznet
May 24, 2009 06:50 PM
Fook_me_honda
Jan 9, 2008 11:58 PM
ringgold
Sep 29, 2004 12:02 PM
egizzle8
Apr 7, 2004 06:55 PM
Timmayeg
Dec 3, 2002 10:19 PM
