Timing Belt life
Old Nov 20, 2003 | 05:55 PM
black_bb1's Avatar
Default Timing Belt life
Well my question is just how long will a timing belt last. My 96 lude is the s model, the sohc engine was teh sux so I replaced it with a jdm h22 and did the obd1 changeover. Shop said that they get engines that supposedly have 30k miles or less (ya right). The timing belt that went is oem so, im hoping at least, that its the original, I know there supposed to be replaced every 60k but how much longer than that will they go for? Just trying to estimate how many miles are really on my engine,
Old Nov 20, 2003 | 06:07 PM
Cottonwoodz's Avatar
Default Re: Timing Belt life (black_bb1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by black_bb1 &raquo;</TD></TR><TR><TD CLASS="quote">Well my question is just how long will a timing belt last. My 96 lude is the s model, the sohc engine was teh sux so I replaced it with a jdm h22 and did the obd1 changeover. Shop said that they get engines that supposedly have 30k miles or less (ya right). The timing belt that went is oem so, im hoping at least, that its the original, I know there supposed to be replaced every 60k but how much longer than that will they go for? Just trying to estimate how many miles are really on my engine, </TD></TR></TABLE>
Are you saying that your timeing belt broke on the JDM motor?
Timeing belts are to be changed every 90K miles.
Old Nov 20, 2003 | 06:20 PM
JG Luder's Avatar
Default Re: Timing Belt life (Cottonwoodz)
Timing belts are replaced at or by 90k, or WHENEVER your motor is OUT of the car.
If you bought a JDM motor, you should've changed the belt before even THINKING about install.
Old Nov 20, 2003 | 07:52 PM
black_bb1's Avatar
Default Re: Timing Belt life (Lone Luder)
ouch 90k. Ya looking back on it I should have done that and a few other things, which I realized 3 months AFTER it went in and the water pump went (which was another perfect time to do the timeing belt) but just like you said in ur modifying manifesto, modifying cars is a trial and error learning experience. This is my first attempt at modifying a car beyond bolt ons so im learning alot as i go along. Things like what I should have done before the engine went into the car, oh well.
Old Nov 21, 2003 | 09:19 AM
SKDRCR's Avatar
yes brothaman,
research, research
nursepaige
Aug 26, 2009 06:49 AM
thunderboy
Aug 21, 2008 05:05 PM
924doorEG
Jan 18, 2008 01:36 PM
m_cough
May 22, 2007 07:50 PM
jjaeschke2
Apr 7, 2003 11:05 AM
