OBD1 & O2 sensor
Old Nov 20, 2003 | 04:56 PM
BI8B's Avatar
Default OBD1 & O2 sensor
from what i heard, OBD1 only need one O2 sensor? so if i'm running a straight pipe, it won't throw a check engine light? any other advantages to go from OBD2 to OBD1?
Old Nov 20, 2003 | 07:40 PM
hondaZvic's Avatar
Default Re: OBD1 & O2 sensor (BI8B)
that is correct. obd1 = 1 o2 sensor. u can run a straight pipe with out getting a CEL.
umm..
obd1 ecu is tunable
obd2 ecu is not.
obd1 has less sensors to worry about
obd2 has more. more of a headache.
Old Nov 20, 2003 | 10:03 PM
BI8B's Avatar
Default Re: OBD1 & O2 sensor (hondaZvic)
will a chipped OBD1 ECU run a CEL?
can i use my stock OBD2 o2 sensor or will i need a OBD1 o2 sensor?
Modified by BI8B at 11:37 PM 11/20/2003
Old Nov 20, 2003 | 11:10 PM
poison's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BI8B &raquo;</TD></TR><TR><TD CLASS="quote">will a chipped OBD1 ECU run a CEL?
You just need a jumper harness with an OBD1 ecu. All OBD2 O2 sensors are the same.
Old Nov 20, 2003 | 11:26 PM
BI8B's Avatar
Default Re: OBD1 & O2 sensor (poison)
so all obd1 and obd2 sensors are the same?<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by poison &raquo;</TD></TR><TR><TD CLASS="quote">
You just need a jumper harness with an OBD1 ecu. All OBD2 O2 sensors are the same.</TD></TR></TABLE>
you said all OBD2 sensors are the same. so, i'm guessing all obd2 and obd1 sensors are all the same? 4 wire?
Old Nov 21, 2003 | 07:10 AM
hondaZvic's Avatar
yes u can use the obd o2 sensor.
Old Nov 21, 2003 | 11:01 AM
BI8B's Avatar
do the dizzy wires have to be switched around?
Old Nov 21, 2003 | 01:15 PM
Katman's Avatar
I think what poison meant was that all OBD1 & OBD2a/b 02 sensors are the same, which is totallly true.
When you use a jumper harness to convert OBD2a/b to OBD1, you don't need to worry about any wiring at all. It's all done within the jumper harness. Thats what makes a jumper harness soo coool -- plug n' play!
Old Nov 21, 2003 | 02:33 PM
BI8B's Avatar
Default Re: OBD1 & O2 sensor (Katman)
thanks for the info.
l1l_r1cky
Feb 28, 2012 01:27 AM
724chris
Jan 23, 2010 07:04 PM
redsolturbo
Jul 23, 2007 07:08 AM
fanoftheb00st
Jun 16, 2007 08:27 PM
elmalouno
Jul 18, 2004 08:55 PM
