will hasport EF Bseries mount kits fit DA?
no, they won't fit. If they did that would mean that ef and da mounts were the same, thus eliminating the need to buy a mount kit when putting a b series in an ef.
Place racing makes replacement mounts for the DA. Their site is down right now, but you can find info and buy them from http://www.overboost.com
i have a question too...i was was doin the auto to manual swap in a g2 93 teg would i have to buy the mount kit or could i just use the mounts i get from the teg xsi b16 im getting?
your integra comes with a b - series engine, the stock mounts u have now will work, as well as the ones from the xsi, as long as u are SURE the b16 is from the XSI and not a SIRII civic.
Also to add, the width of the EF mount kits are not as wide as the DA frame brackets. Example... I was going to use a billet HCP EF driver side mount for the hell of it for some "bling" but upon closer examination, the EF mount width is narrower than the DA, so there would be too much play in between the bracket and the motor would basically move/rattle around rather than sit in there smoothly. The DA rear subframe also has a slightly different contour from the EF rear subframe so the rear mount won't sit flush on there, and the tranny mount will bolt to the tranny, but will not line up with the passenger side framerail mount.
go to g2ic and do a search. the auto to manual swap has been gone over a few times. If I remember correctly the mounts are the same except for the side tranny mount. And its an auto/manual difference, not a year difference. The solution was just to shim the mounts and it works fine. I'm not 100% about the details....but a search on g2ic.com should give you all the info you need.
typeeg
22
Jul 23, 2004 07:09 AM
