Overheating tranny?
Old Nov 20, 2003 | 02:33 PM
WONG FRIED RICE's Avatar
Default Overheating tranny?
On a hot day, after driving around for some time, when i come to a stop and try shifting gears, it is very very difficult to shift into gear, and reverse...blah reverse just grinds and grinds every time i ATTEMPT to put it into gear....if i do put into gear i have to suffer hearing the harsh crunching. Any ideas??
tranny fluid? i dunno, i've done some searching but couldn't find anything.
Old Nov 20, 2003 | 02:39 PM
mmuller's Avatar
Mad Scientist
Default Re: Overheating tranny? (JDMB16ACRX)
try changing your tranny fluid.
gm synchromesh
Old Nov 20, 2003 | 02:49 PM
mattssi's Avatar
Default Re: Overheating tranny? (mmuller)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mmuller &raquo;</TD></TR><TR><TD CLASS="quote">
gm synchromesh </TD></TR></TABLE>
Honda MTF, I wouldn't use anything else...
Old Nov 20, 2003 | 02:52 PM
mmuller's Avatar
Mad Scientist
Default Re: Overheating tranny? (mattssi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mattssi &raquo;</TD></TR><TR><TD CLASS="quote">
Honda MTF, I wouldn't use anything else... </TD></TR></TABLE>
So....you tried gm synchrmesh?if not say its bad....
Old Nov 20, 2003 | 02:59 PM
mattssi's Avatar
So....you tried gm synchrmesh?if not say its bad....</TD></TR></TABLE>
I'm not saying it's bad, It's just common knowledge that honda tranny's were designed to be used with honda MTF? I think it works the best. Why go out of your way to use something else?
Old Nov 20, 2003 | 03:04 PM
mmuller's Avatar
Mad Scientist
I'm not saying it's bad, It's just common knowledge that honda tranny's were designed to be used with honda MTF? I think it works the best. Why go out of your way to use something else? </TD></TR></TABLE>
because its BETTER, its your choice....Search and you'll see the light
Old Nov 20, 2003 | 03:06 PM
mattssi's Avatar
I have used both, and i made my choice! To each is own i guess!
Old Nov 20, 2003 | 05:56 PM
so u think it's tranny fluid? do u think it could be lack of?
Old Nov 20, 2003 | 06:51 PM
tjbizzo's Avatar
Screw you guys, I'm... going... home.
It sounds to me like your clutch isn't disengaging completely when your car is hot. I don't know what would be making your car do this but have you checked your clutch pedal adjustment and your clutch master cyl fluid level (if hydro) or cable adjustment (if cable)? I had similar symptoms once and it turned out to be oil leaking onto the clutch disk. Normally you would think oil on disk = slippery, right? Well once it gets cooked on there by heat, it turns into something like tar and really *drags* on the clutch when you try to shift. I could FORCE it into gear, but it wasn't pretty.
Old Nov 20, 2003 | 07:41 PM
Default Re: Overheating tranny? (tjbizzo)
hmmm i will definately check that out.... thanks for the info!! good ideas!! i'll let you guys know when i find out what happend
bertsb18hatch
Apr 6, 2008 09:45 AM
90gs
Nov 1, 2006 12:37 PM
97turboteg
Sep 7, 2006 03:45 PM
LorenGeist
Aug 14, 2004 12:05 PM
743power
Oct 9, 2003 11:41 PM
