Car dies right after being cranked up when its already warmed up
Old Nov 20, 2003 | 01:00 PM
Casey's Avatar
Default Car dies right after being cranked up when its already warmed up
Ive got a gsr swap in my 92 hatch. This only happens once the car has been runnig for a while, and then is turned off. When I turn it over, it revs up to 1500, but dies right after. Ive been told possibly my tune is off(possible) or the main fuel injection relay is going bad. How do i check to see if the relay is bad? What do they cost to replace? thanks
Old Nov 20, 2003 | 05:41 PM
Casey's Avatar
Default Re: Car dies right after being cranked up when its already warmed up (Casey)
Old Nov 20, 2003 | 08:34 PM
MajorPayne's Avatar
I know what the problem is, the hamsters water bottle is getting clogged, so hes not running in the wheel fast enough. Haha, I'm just kidding, let me know what you find out.
BUMP for casey.
Old Nov 22, 2003 | 01:00 PM
92-EG6's Avatar
Default Re: Car dies right after being cranked up when its already warmed up (gsr1775)
I GOT DA SAME PROBLEM ON DA SAME EXACT SETUP. I THINK MAYBE DA FUEL PUMP OR FUEL FILTER NEEDS 2 BE CHANGED.
Old Nov 22, 2003 | 01:03 PM
Casey's Avatar
Default Re: Car dies right after being cranked up when its already warmed up (92-EG6)
i was told it could be my temp sensor, since its broken, the motor doesnt know if its already heated up or cold and may be giving too much or too little gas
StegRX
Feb 8, 2016 07:54 AM
brisza55
Oct 30, 2011 08:02 AM
JDM94HATCH
33
Jan 15, 2007 11:07 PM
shorty
Aug 25, 2005 03:31 PM
snoochtodanooch
11
May 22, 2005 01:03 PM
