Help me take my axle out? LS teg....
Old Nov 20, 2003 | 09:54 AM
94lsboost's Avatar
Default Help me take my axle out? LS teg....
Drivers side axle, 94 LS integra....Do you just pry on the rear of the inner cv joint by using the mount for leverage? And how do you get it all the way out? The only way I see is to take the bottom bolt out, where the spindle that surrounds the axle comes together...but I thought the spring was compressed? it looks like it by looking at the bushing, so i'm not sure....please help asap.
Old Nov 20, 2003 | 10:03 AM
96-EJ6 B18C's Avatar
Default Re: Help me take my axle out? LS teg.... (94lsboost)
Seperate the lower ball joint and the tie rod end...then remove the 17mm through bolt on the bottom of the strut assembly...remove the 32mm nut on the end of the axle...pull the hub and the axle apart and let the hub hang to the side...with a pry bar gently pry the axle out of the intermediate shaft...now just slip the axle out from between the strut assembly and the lower control arm. Just dig in to it...its cake
Old Nov 20, 2003 | 10:15 AM
SuzukaBlueAP2's Avatar
Default Re: Help me take my axle out? LS teg.... (96-EJ6 B18C)
on the driver's side, isn't there a bracket that is bolted to the block with 3 bolts ?
Old Nov 20, 2003 | 10:33 AM
Default Re: Help me take my axle out? LS teg.... (urbanracer98)
absolutely NOT that is the intermediate shaft and it doesn't need to come out to change the axle. the axle will seperate from that shaft if you pry on it a bit.
Old Nov 20, 2003 | 10:44 AM
DUH! Intermediate shaft. on me
Old Nov 20, 2003 | 10:45 AM
LOL have a you'll feel better!
Old Nov 20, 2003 | 01:06 PM
94lsboost's Avatar
I've been prying on it for a while, the axle is separated at the inner cv joint, so the only thing there is the housing for the inner cv, i'm trying to pry it out so i can put the axle back together easier....but it aint' happening....i've pried on it for like 3 hours ...no luck....
Old Nov 20, 2003 | 03:19 PM
Is it all rusted or something???
Old Nov 20, 2003 | 06:10 PM
IN VTEC's Avatar
Whack it with a small sledge hammer. It'll come out.
If it comes down to it, remove the int shaft. It's just 3 dowel bolts and a quick pry with a thin screwdriver to remove it. Then whack it with a small sledge hammer.
Old Nov 21, 2003 | 04:47 AM
94lsboost's Avatar
Default Re: Help me take my axle out? LS teg.... (IN VTEC)
thanks, I'm taking the sledge to it today...it WILL come out before I sleep again.
fuckmylife777
Oct 10, 2012 05:48 PM
thw_goalie
Aug 12, 2012 10:39 AM
lowtegsr
Feb 1, 2008 07:18 AM
91zSi
30
Aug 4, 2005 04:09 PM
