onNew Brake Master Cylinder
Remove the two 12mm bolts, remove the two brake hydraulic lines. Bench bleed the new M/C, and reverse the order and bleed your brakes.
The order for bleeding brakes is:
Rear Passenger
Front Driver
Rear Driver
Front passenger
Rear Passenger
Front Driver
Rear Driver
Front passenger
Is it neccessary to bench bleed the new master cylinder?
EDIT: After searching, it appears that it is.
Modified by mycivicstoo(s)low at 3:02 AM 11/21/2003
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by smeister »</TD></TR><TR><TD CLASS="quote">I always thought it was start from furthest away from M/C and work your way closest?! Can someone clarify this?</TD></TR></TABLE>That's old school. The bleeding order depends on which circuit is likely to push bubbles into which other circuit. With different ABS systems they all have different bleeding orders - check a Helm book for YOUR car.
But I think if you bleed the wrong order, the only problem is you might have to go around a couple more times before all the bubbles are out.
crx00
May 30, 2005 08:45 AM
I_love_my_HONDA
Apr 24, 2005 07:34 AM
