Need help installing an AVC-R boost controler
This is what I have saved in my notepad. "The com port of the solenoid valve goes to the top port of the wastegate. The NC port of the solenoid valve connects to a vacuum source. The side port of the wastegate also needs a vacuum source."
Hope that is what you are looking for. If not go to apexi's webpage and download the manual.
-Ryan
-Ryan
I just reconntect the lines for my avc-r. Does this sound correct.
I ran the top port to the com like was said. Then I ran the side port to a t in the FPR vacume line. Then I T the tube again near the waste gate and ran that to the NC on my selond for the avc-r is that okay or is that two may T's?
hy_revs
Dec 4, 2003 06:47 AM
