Need help installing an AVC-R boost controler
Old Nov 19, 2003 | 05:53 PM
ProjectLudeSiR's Avatar
Default Need help installing an AVC-R boost controler
hey, i have a prelude and need help installing the solenoid valve, i need to know where the vacuum hoses go to please help
Old Nov 19, 2003 | 05:56 PM
ladysman's Avatar
Default Re: Need help installing an AVC-R boost controler (ProjectLudeSiR)
Depends on if it is a internal or external wastegate on your car.
Old Nov 19, 2003 | 06:44 PM
Default Re: Need help installing an AVC-R boost controler (ladysman)
its an external
Old Nov 20, 2003 | 12:30 AM
Kwuaymaikrup's Avatar
This is what I have saved in my notepad. "The com port of the solenoid valve goes to the top port of the wastegate. The NC port of the solenoid valve connects to a vacuum source. The side port of the wastegate also needs a vacuum source."
Hope that is what you are looking for. If not go to apexi's webpage and download the manual.
-Ryan
Old Nov 20, 2003 | 12:32 AM
EDIT- Well I guess the first post showed up after all.
Old Dec 5, 2003 | 06:32 PM
underpressure02's Avatar
I just reconntect the lines for my avc-r. Does this sound correct.
I ran the top port to the com like was said. Then I ran the side port to a t in the FPR vacume line. Then I T the tube again near the waste gate and ran that to the NC on my selond for the avc-r is that okay or is that two may T's?
CoreyR
Apr 11, 2005 07:09 PM
rev-speed
Dec 4, 2003 06:12 PM
hy_revs
Dec 4, 2003 06:47 AM
boostedel
Feb 22, 2003 02:37 PM
GruvyTune
Oct 24, 2001 08:09 PM
