checking oil...
Old Sep 12, 2001 | 05:45 PM
corky2k's Avatar
New User
Default checking oil...
when are you supposed to check the oil level? do you check it right after driving the car, a little after driving the car, or when the engine is cold? i want to know because i have heard so many things and i've tried every method finding different results each time...
MIke
Old Sep 12, 2001 | 05:51 PM
johng's Avatar
Default Re: checking oil... (corky2k)
Ideally, about 5-10 minutes after driving the car and allowing it to come up to temperature.
Old Sep 12, 2001 | 05:52 PM
92Si's Avatar
New User
Me personally... I think that you will get the best reading when the motor has sat, because all of the oil will have had time to drain to the pan. I don't think that you're going to see a huge variance either way though. Just check it regularly and get an oil pressure sensor if you are worried about running low.
HTH
Old Sep 15, 2001 | 04:34 PM
976's Avatar
976
New User
Default Re: checking oil... (92Si)
Yeah, dead cold is best...
Old Sep 15, 2001 | 07:37 PM
Tripz's Avatar
New User
I like to check mine about 20-30 minutes after the car has been shut off. I've tried many different methods aswell and came up with a couple conclusions. Your oil level will be a bit higher when the engine is warm (i guess because oil expands when hot??) and a bit lower when the car has been sitting (like overnight). It's pretty wierd because by then, u would expect all your oil to be drained off all the internal parts and the pump but it ends up being lower than if u were to check your oil let's say half hour after shutting off your engine.
XxRoCkMaNxNEOxX
Nov 28, 2004 09:17 AM
io_burn
Jan 5, 2003 10:19 AM
Qwikrex
Dec 11, 2002 03:05 PM
B18Redline
Jun 10, 2002 02:40 PM
B18Redline
Jun 10, 2002 11:35 AM
