Should I be worried about this shit froming on my sleeves!!????
Old Nov 19, 2003 | 03:59 PM
leadfoot78's Avatar
Default Should I be worried about this **** froming on my sleeves!!????
I left my block in the garage for like a week, and I got rust on the sleeve walls and some dirt spots on the coolant passages. The dirty spots won't even some of with brake cleaner and steel wool. Should I just leave it alone till I'm ready to do a bore, hone and deck or is this a serious problem???
Old Nov 19, 2003 | 04:02 PM
boosted_dc2's Avatar
Default Re: Should I be worried about this **** froming on my sleeves!!???? (leadfoot78)
i dont know but what kind of sleeves are those???
Old Nov 19, 2003 | 04:04 PM
Full-Race Henry's Avatar
Default Re: Should I be worried about this **** froming on my sleeves!!???? (boosted_dc2)
they are darton sleeves by arizona racing machine. he is the only one with that style.
specie's Avatar
If you're going to bored it out, then it shouldn't be a problem. When not working on your block, you should put some oil on the cyclinder wall and put the block in a garbage bag...it'll stay clean and oxidation-free.
Old Nov 19, 2003 | 04:06 PM
BoostingSnail's Avatar
I would just take some ATF or oil on a rag and just go over everything so it doesnt for anymore rust...that is just surface rust..nothing to get worried about since you say you are going to get it bored and honed
EDIT:Yeah what every one else has said..looks like we all posted at the same time nearly
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by leadfoot78 &raquo;</TD></TR><TR><TD CLASS="quote">I left my block in the garage for like a week, and I got rust on the sleeve walls and some dirt spots on the coolant passages. The dirty spots won't even some of with brake cleaner and steel wool. Should I just leave it alone till I'm ready to do a bore, hone and deck or is this a serious problem???</TD></TR></TABLE>
call adam and ask him. I think you should be fine. just spray it down with wd-40 for now. after you get it bored/honed, it should be good.
Old Nov 19, 2003 | 04:39 PM
integranator's Avatar
Default Re: Should I be worried about this **** froming on my sleeves!!???? (jerseykid609)
When the bore and hone the cylinders your machinist SHOULD hot tank it-- this should get all that dirt out of the coolant passages!
Old Nov 19, 2003 | 04:45 PM
leadfoot78's Avatar
Right after I saw the rust I cleaned it off with steel wool and WD-40, then I tried brake cleaner and steel wool and nothing will take off the dirt spots in the coolant galley. What do u guys think it is?? It dosn't look like rust. And the block has been in a plastic bag sprayed with WD40 for a few days now. Thanx
martin
Old Nov 19, 2003 | 05:31 PM
Mr. Softee's Avatar
it has to be some kind of corrosion
spoolinlude's Avatar
I live under a rock
true bare iron rusts in a matter of hours, anytime you have bare iron exposed to the atmosphere it will rust, since there's always oxygen (duh) in the atmosphere....... so basically you want to keep it covered... i recommend this stuff called dura-lube if you can still find it anywhere, wd-40 if not, and always wrap it in a bag, to keep as much moisture out as you can
MR.johnson
Jul 18, 2012 06:44 PM
fourdoorturbo
Jun 28, 2008 12:19 PM
earl
Jun 15, 2005 08:45 AM
BeavisB16
Feb 10, 2003 10:37 AM
shingles
Oct 22, 2002 08:25 PM
