Just got my turbo kit in...quick question...
Old Nov 19, 2003 | 02:24 PM
jdkornlp's Avatar
Default Just got my turbo kit in...quick question...
I just received my greddy turbo kit for my 99 si. I bought it used and everything appears to be there however there is one question i have. The picture below, i cant figure out where that screws into. I think that im missing a flange for the oil pan or does it not need one? Am i supposed to just drill the same size whole into the oil pan then screw this in? Or is there something missing? Thanks.
Old Nov 19, 2003 | 02:27 PM
Canuk_SiR's Avatar
Default Re: Just got my turbo kit in...quick question... (jdkornlp)
you need to get oil back into the oil pan once the oil drains from the turbo, and the best way to do that is to either get a fitting welded to the pan, or get a set of fittings that can clamp between the oil pan. Also, what size fitting is that? it looks like a 1/8"NPT, and that would be way too small for an oil return. Returns should be 3/8" or larger, just to be safe.
Old Nov 19, 2003 | 03:23 PM
ScrapinSi's Avatar
I think thats your oil feed line
Old Nov 19, 2003 | 03:54 PM
jdkornlp's Avatar
Default Re: Just got my turbo kit in...quick question... (ScrapinSi)
No, its the oil return. It's 1/2" fitting. I just went to home depot and bought a flange from the plumbing section that looks like it'll work nicely. Anyone know any good alternatives to welding?
Old Nov 19, 2003 | 04:39 PM
ATS*Mark's Avatar
OG triple OG
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdkornlp &raquo;</TD></TR><TR><TD CLASS="quote">No, its the oil return. It's 1/2" fitting. I just went to home depot and bought a flange from the plumbing section that looks like it'll work nicely. Anyone know any good alternatives to welding? </TD></TR></TABLE>
yes , not welding it
Old Nov 19, 2003 | 05:13 PM
Archidictus's Avatar
Unceasing Measure
Default Re: Just got my turbo kit in...quick question... (Hella_JDM)
JB Weld that sum bitch. That's what I've been told, anyhow, but if you're going to take your oilpan off anyway you might as well have it done "right".
Old Nov 19, 2003 | 05:49 PM
Cramerox's Avatar
Default Re: Just got my turbo kit in...quick question... (Archidictus)
well depending on where you want to put that piece will depend on what you need.
you can buy this for the turbo and screw right in:
Or you can get a male adaptor to weld on the oil pan that will screw into that piece.
Old Nov 19, 2003 | 05:50 PM
redboost10's Avatar
Default Re: Just got my turbo kit in...quick question... (Cramerox)
are those for both the feed and return?
Old Nov 19, 2003 | 05:51 PM
HXMan's Avatar
Default Re: Just got my turbo kit in...quick question... (tgh99si)
Yes. Feed and return.
Old Nov 19, 2003 | 06:00 PM
FredoSP's Avatar
your greddy feed line is SS correct? Personally I get a SS return line while everything is off
Luis Valdez
Honda Civic (2006 - 2015)
Feb 8, 2009 06:03 PM
dart2.2
Jul 25, 2008 07:01 AM
dunkd
Mar 8, 2004 09:07 PM
GruvyTune
Nov 12, 2001 04:07 PM
tsjag17
Oct 30, 2001 04:09 PM
