Changing oil on cold engine?
Old Sep 12, 2001 | 01:47 PM
Splat's Avatar
Collector-o-Guns and Drinker
Default Changing oil on cold engine?
Just curious. Haven't driven my car this week, and need to change the oil before NOPI. Should I warm it up first or just go nuts as-is? Opposing theories, perhaps? I'm sure warm oil will drain better, but I use Mobil1 5W30, and it's been 95 degrees in the garage all week.
Thoughts?
Old Sep 12, 2001 | 01:51 PM
yoshi234's Avatar
I shoot brides
Default Re: Changing oil on cold engine? (itr009)
I"d still run the motor a bit just to get it flow'n little bit better
Old Sep 12, 2001 | 01:56 PM
Splat's Avatar
Default Re: Changing oil on cold engine? (yoshi234)
Yeah, but "runnin' just for a little bit" on my car means 15 minutes. Must be nice to the cams!!
Ah well, I got time
Old Sep 12, 2001 | 01:57 PM
Cosworth's Avatar
Yup, it's recommended that you get your car up to the "operating temp" before doing an oil change.
Old Sep 12, 2001 | 02:04 PM
D's Avatar
D
leave it cold. if it's been sitting for a week, the vast majority of the oil has drained from the head into the pan.
if you're replacing filter.... fill the filter with as much new oil as possible... then when you start the engine, fresh oil gets to the head faster, without having to build pressure through the filter.
D
Old Sep 12, 2001 | 02:26 PM
blaze's Avatar
Default Re: Changing oil on cold engine? (D)
get the engine close to operating temp.... and with a cold engine, the damn filter is hard to get off.
Old Sep 12, 2001 | 02:54 PM
jond's Avatar
Default Re: Changing oil on cold engine? (blaze)
I thought the reason the engine should be warm is because the oil holds more dirt when warm. Anyone?
Old Sep 12, 2001 | 05:17 PM
t's Avatar
t
D
When you parked your car it was warm and all the dirt and crap has settled enough to the bottom already, no need to warm it up for 15 minutes and have the dirt and crap recirculate than drain when its warm. (Although it is ideal when it is warm, but not necessary, especially since the time the car sat)
Old Sep 12, 2001 | 05:54 PM
itr501's Avatar
in temps like that, don't u want to be using 10w30?
Old Sep 12, 2001 | 06:31 PM
Splat's Avatar
Default Re: Changing oil on cold engine? (itr501)
Been using 5W30 since the first change. Doesn't burn a bit
return_2020
Honda Civic (2001 - 2005)
Sep 2, 2006 06:44 PM
5lugcivic
13
Aug 20, 2006 05:53 PM
Babakarab
Jun 30, 2006 08:30 PM
EM1VtecSi
Aug 1, 2004 01:58 PM
2005 TSX
Nov 4, 2002 08:41 PM
