how reliable is h23 vtec?
A lot of guys have broken cranks, spun bearings, and popped timing belts with the h23 vtec. But there are a handful of people out there that have successfully pulled this hybrid off... that's because they did their research and did not take any short cuts through the process.
Personally, I would just sell the h23, buy a h22, p&p the head, add a jun 3 valve-train with cams and call it a day.
i have the h23 vtec it kinda scars people and the call me crazy...stupid non intelligent personell that don't know about cars. i love the h23 vtec. it works for me. slight electrical problem with it in the begining but now running boost through it and it seems to love it. if you do it correctly it's worth it. but if not sure about it just go all h22.
If you dont rev it too high, in theory its supposd to hold out. I haven't heard of anybody blowing their H23 vtec due to crank without ever having gone over 7200 RPM. (stock H22 redline ?)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92preludeSIwp »</TD></TR><TR><TD CLASS="quote">i have the h23 vtec it kinda scars people and the call me crazy...stupid non intelligent personell that don't know about cars. i love the h23 vtec. it works for me. slight electrical problem with it in the begining but now running boost through it and it seems to love it. if you do it correctly it's worth it. but if not sure about it just go all h22. </TD></TR></TABLE>
I'd agree with this person.... You really need to do some research and have a fully built motor for that....because just stock h23vtec your bearings will go out soon and a new block will be needed..... In the long run it will eventually start to wear our faster than a H22. I had a H23vtec and spun a bearing.... so I went with h22 all the way... its great now but without the tq.
so true about the reliable part. if you don't do it correctly then you could be SOL. if you go with the h23 vtec then make sure it's done correctly find some people who have it in the area and see where they got it done and then get to know the people. or just try it your self and if have any questions at all pm or email me.
Well, after meeting my first Ricer ever...and now understanding their mental that revving the motor higher is better...I now understand why so many H23VTECs have failed.
Build the H23VTEC and don't rev it past 6500...you should be fine.
but AndyD, see then you have to tune the vtec down a bit (when it kicks on) so you get full power out of it, i have the h23vtec and i can rev to 8500 no problems, now none of my internals are stock, and i have put almost 40k on this motor. and when and if it blows i will build me a new h23vtec. i am only 17 and i run it pretty hard alot....i feel the need for speed. muhahaha
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92preludeSIwp »</TD></TR><TR><TD CLASS="quote"> now none of my internals are stock,</TD></TR></TABLE>
what crank are you using then
how often do you rev past 8k?
I have over 15,000 on my h23vtec(beater) hard miles also. I use a P72ecu and shift the car at 8K and have been with no problems as of yet. So I think its fine from mypersonal experiance. The setup has been in the car for over a year. I have had a twoh23vtec motors brought to me which have locked up or spun a bearing and both car left the oil orface in the block
which should be removed because they are in the head of the 22 but in the block of the 23 dunno if that is the full problem but i am sure it didnt help any.
H23VTEC + P72 + Hi Revs + 10k miles = below picture.
No, I didn't build it.....I bought the car with the blown engine for cheap after the previous owner subjected the poor car to this. I'm rebuilding - not with the H23vtec. Just buy an H22.
first of all if you dont know what you are doing and are not mechanicaly sound. why in the world would you attempt to run H23-V. if you build it right and take care of it you should be all set. H22 oil pump and oil squirters protect your internals alot better than h23 stock. balancing cranck and shaving it down for thicker bearings, eliminates more chances of spun bearings. and reving high is not the way to make reliable power with big dissplacement. if i hear another person saying 6500 rpm is a good redline i would tell them to shut up before i strangle them because they have never owned one. ideal rev i beleive should be around 7200-7400. i rev to 7400 myself running stock p13 at the moment. make sure you have h22 oil pump and oil squirters and you build the damn thing right. these kind of revs are only good with stock cams because you have to rev higher to make power with them. higher lift cams are the solution to make power and lower your redline. people that drive h23-v daily, and take it to the track sometimes should have no prob with revs around 7200. lowering the redline would be for more agressive people that like high revs all the time
. H23-V is only as reliable as the person that builds right and takes care of it.
agreed i still take mine to 8k lol only cost me a head gaskit kit to put the thing together still on stock bottom end with a j-spec head i had layin around. the bottom end has 158 on it not and was around143 when i got the car for 800 bucks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by phil2000 »</TD></TR><TR><TD CLASS="quote">
That picture seriously disturbes me.
</TD></TR></TABLE>That picture seriously disturbes me.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by phil2000 »</TD></TR><TR><TD CLASS="quote">H23VTEC + P72 + Hi Revs + 10k miles = below picture.
WHOA DUDE! That looks just like mine!! https://honda-tech.com/zerothread?id=441374
only lasted 7000 miles
This was built by my current engine builder for my h22a as well. He is an excellent engine builder as you can see by my power numbers and this engine has already hit nearly 20000 miles. I don't fault him for what happened, h23 is not meant to rev high. For those that rev to 8000-8500 it's only a matter of time. Possibly your crank is strong and that's good, in my case it wasn't
Knife-edging was probably not the smartest thing in the world either.
</TD></TR></TABLE>WHOA DUDE! That looks just like mine!! https://honda-tech.com/zerothread?id=441374
only lasted 7000 milesThis was built by my current engine builder for my h22a as well. He is an excellent engine builder as you can see by my power numbers and this engine has already hit nearly 20000 miles. I don't fault him for what happened, h23 is not meant to rev high. For those that rev to 8000-8500 it's only a matter of time. Possibly your crank is strong and that's good, in my case it wasn't
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by satan_srv »</TD></TR><TR><TD CLASS="quote">
Knife-edging was probably not the smartest thing in the world either. </TD></TR></TABLE>
Hah....yeah I have a main cap split in half just like that too
And somehow I don't think it was the knife-edging that did you in......yours broke in the same spot as mine, doesn't look like the material you took off it caused any stress concentrators or anything. What do you think?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LudeyKrus »</TD></TR><TR><TD CLASS="quote">I still maintain my opinion that there has to be a resonant frequency around 8k rpm; they both snapped right near the center maincap</TD></TR></TABLE>
I also strongly side with that opinion, that and the fact that the cranks are obviously different in design, or better worded, the H23 cranks were NOT designed for high RPM use.
if you turn down vtec (when it kicks in ) and you redline at lets say 6800 then you only us it from 6200 to 6800 you aren't getting your full power band usage from that you can still make power past 6800 so if you tune the vtec down to kick in a 58 then you will have a better power band.
it is a stock crank but i have balanced it and i have grinded it down for better bearings, so there for it really isn't stock any more sorry for the confusion. i used to rev to 8000-8500 all the time, but that was when i just finished it and i was testing it out, but i mean i know have just over 40k on it now, and i can still hit 8300 on it did it yesterday. just to see if i could. when i first finished it i would actually bounce it off red line and hit 9053, v-afc told me. i have yet to have a prob, with mine, sorry for idiots that don't know there crap, and blow there engine, o yeah starting Dec, 18 drag stage 3 goes in, i'll fill you in on that later. we shall see how it all works.
