B series enine question.....help
Old Nov 18, 2003 | 08:28 PM
alergic2fatchix's Avatar
Default B series enine question.....help
I have a B series engine, but i don't know what kind it is.
it only says honda motor company on the valve cover.
it looks kinda like this-----> http://www.hmotorsonline.com/shop/images/b18b1.jpg
is there any way i can tell what type it is???
thanks...
Old Nov 18, 2003 | 10:15 PM
EGtoDC2's Avatar
Default Re: B series enine question.....help (alergic2fatchix)
that engine you posted the link to is a nonvtec b18b. they are from the integra LS/RS/GS 94+
does the valve cover look EXACTLY like the one in picture? if so, then it is a b18b.
there is an engine block stamp on the block that will give you the exact code, but this doesn't necessarily mean you have vtec or not since you can mate a nonvtec block to a vtec head.
Old Nov 18, 2003 | 10:31 PM
Newman's Avatar
New User
You have there (either) an OBD-2 B18B LS motor from a 96-01 Integra, or a JDM B20B motor out of an 97-00 Orthia wagon.
Read what the block stamp says and you can tell what year the motor is as well.
Old Nov 19, 2003 | 11:16 AM
AngelTeg's Avatar
yup, exhaust side, tranny side theres a stamp on the block... read it. by looking at the intake manifold on that motor, I believe its a B18B... simply because the B20 factory intake manifolds are quite tall.
-Mike
Old Nov 19, 2003 | 01:23 PM
thanks alot.
ans also, what is a frankestain motor??? or something like that.
and is the b18b a good engine to work on???
thanks....
Old Nov 20, 2003 | 02:31 PM
96BlackHB's Avatar
Frankenstein motor refers to a VTEC head paired with a Non-VTEC block. B18b is a good motor as far as reliability goes and its not bad on power either(compared to similar sized motors by other manufacturers). Lower compression makes them a good canidate for boost (turbo or supercharger). Use the search function and I am sure you can find any info you are seeking.
Old Nov 20, 2003 | 02:48 PM
doublejz's Avatar
Default Re: B series enine question.....help (96BlackHB)
nice and clean
Old Nov 21, 2003 | 09:33 AM
crxtreme89h's Avatar
Default Re: B series enine question.....help (doublejz)
Did this motor just fall in your lap or what?
MTracing
Sep 11, 2011 08:51 AM
94b18hatch
Oct 27, 2007 09:42 AM
neve12f0ll0w
May 18, 2006 05:38 AM
Blanket Jackson
Dec 29, 2005 10:16 AM
Leimokei
May 30, 2002 11:34 AM
