( HOW TO ) tuning valves on b18c
Old Nov 18, 2003 | 10:18 AM
drivfastr's Avatar
Default ( HOW TO ) tuning valves on b18c1
I heard that when the camshafts are removed from the head the valves must be retuned, what is involved in this process
Modified by drivfastr at 8:19 PM 11/18/2003
Old Nov 18, 2003 | 11:24 AM
dwn-shift's Avatar
Default Re: ( HOW TO ) tuning valves on b18c1 (drivfastr)
VAlve lash How to
http://www.c-speedracing.com/h...t.php
JimBlake's Avatar
Probably you heard it's good to adjust your valve lash after you put it back together. If you're lucky and everything goes in perfect, MAYBE you just measure and it's OK.
If you have adjustable cam sprockets, adjust them by tuning on a dyno; but I suppose you can put them back in the same position as before you took it apart?
b18sihatch
May 10, 2007 07:46 PM
IntegraXSi
Nov 13, 2005 05:18 PM
93si
Oct 6, 2003 01:41 PM
B18C-Hatch
Feb 25, 2003 02:45 PM
MysticAzn03
Feb 11, 2003 01:46 PM
