SOHC TURBO VS DOHC TURBO
Old Nov 18, 2003 | 08:52 AM
GSRHATCH187's Avatar
Default SOHC TURBO VS DOHC TURBO
WHAT UP GUYS I HAVE A GREDDY TURBO KIT I HAVE FOR MY 99 GSR MOTOR, IN MY 92 SI, ALL I NEED IS PIPING FOR THE INTERCOOLER AND TURBO, CAN I USE THE SAME PIPES FROM A SOHC GREDDY TURBO KIT? OR DO I NEED TO BUY PIPING FOR THE MOTOR? (GSR) I FOUND SOME PIPING ON EBAY, BUT ITS FROM A SOHC! WILL THE TURBO FROM A SOHC FIT ON THE SAME MANIFOLD AS THE GSR SETUP? SUM1 HELP!
Old Nov 18, 2003 | 10:01 AM
Johnyquest's Avatar
Default Re: SOHC TURBO VS DOHC TURBO (GSRHATCH187)
Make your own. It's always cheaper and easier. Walmart has welders (stick) that can get the job done for $89.
Otherwise, your on your own. I don't know anything about buying a piping kit... They are just pipes. Sorry
Old Nov 18, 2003 | 10:07 AM
Happyman's Avatar
Default Re: SOHC TURBO VS DOHC TURBO (Johnyquest)
The SOHC piping won't fit to my knowledge. And as for if youc an use the Greddy SOHC turbo(15G) on the Greddy DOHC manifold the answer is no. It's td04 vs td05 housings. I don't believe the bolt paterns are the same.
Old Nov 18, 2003 | 10:25 AM
CaptinMcnut's Avatar
you can use a sohc turbo on a dohc manifold
Old Nov 18, 2003 | 10:28 AM
friend has done it on a ls and used a sohc turbo kit
Old Nov 18, 2003 | 10:40 AM
Happyman's Avatar
Default Re: (Darren 92 civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Darren 92 civic &raquo;</TD></TR><TR><TD CLASS="quote">friend has done it on a ls and used a sohc turbo kit</TD></TR></TABLE>
He asked if he could use the SOHC turbo on a DOHC manifold the bolt pattern for the turbo flange is not the same. It cannot be done. You can however get the SOHC manifold and modify it to fit the DOHC head. That can be done.
Old Nov 18, 2003 | 10:45 AM
Tony Starks's Avatar
Default Re: (eh6turbo)
I have intercooler pipes for you that will work with both cars. *see sig*
Old Nov 20, 2003 | 06:18 PM
ok sry didnt know that much thanks now i know atleast you wernt a dick about it just cause i was a newbie thanks for not bein a dick
Old Nov 20, 2003 | 07:42 PM
Tomek's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GSRHATCH187 &raquo;</TD></TR><TR><TD CLASS="quote">WHAT UP GUYS I HAVE A GREDDY TURBO KIT I HAVE FOR MY 99 GSR MOTOR, IN MY 92 SI, ALL I NEED IS PIPING FOR THE INTERCOOLER AND TURBO, CAN I USE THE SAME PIPES FROM A SOHC GREDDY TURBO KIT? OR DO I NEED TO BUY PIPING FOR THE MOTOR? (GSR) I FOUND SOME PIPING ON EBAY, BUT ITS FROM A SOHC! WILL THE TURBO FROM A SOHC FIT ON THE SAME MANIFOLD AS THE GSR SETUP? SUM1 HELP! </TD></TR></TABLE>
why are you yelling?
ExCon
Nov 12, 2005 08:23 PM
crackerjacker006
Nov 1, 2004 04:53 PM
d15b7racer
Oct 8, 2003 06:48 AM
egturbo
48
Jan 19, 2003 06:24 PM
prjctCIVIC
Jul 22, 2001 10:59 PM
