Checking timing, quick question
Old Nov 18, 2003 | 08:42 AM
NotSoFastEX's Avatar
Default Checking timing, quick question
I have recently put on a new distributor cap and rotor and still have not been able to get rid of the pinging while going up a hill. It has diminished but I'm sick of having to use premium dammit! I got a timing light today and I wanted to check timing but I left my haynes manual at my friends house. So my question is:
When adjusting timing how do I put the engine in "service mode"? I know how to use the light and how to do everything but I just dont know which connection I'm supposed to jump.
Also, which side of the engine the number one piston at? I searched and dint find it.
Anyway thanks in advance.
Modified by NotSoFastEX at 7:33 PM 11/18/2003
Old Nov 18, 2003 | 10:35 AM
Default Re: Checking timing, quick question (NotSoFastEX)
ttt want to get this done today
c'mon guys I know thereare some pretty smart guys here, pretty easy question.
Old Nov 18, 2003 | 10:57 AM
badazzaccrd's Avatar
It's underneath the glove compartment. Try searching.
Elvis1977's Avatar
i know that piston #1 is closest to timing belt. I forgot jump connection terminal numbers.
Old Nov 18, 2003 | 11:19 AM
Perfectionist's Avatar
On my 4th gen Civic it was a blue two pin connector under the dash. You don't state the vintage of your Accord and it's probably different.
Old Nov 18, 2003 | 11:29 AM
Default Re: Checking timing, quick question (Perfectionist)
Ok sorry guys. I did start by searching but I didn't think of searching for the location I searched for a general search for a timing how to. After more extensive and complete search, here is the revised question.
On a 94 Accord EX.
Which holes in the service cable do I jump?
I found two pins, one said ABS only so I left it alone, the other was a blue double. One has 3 holes, the other 2.
Sorry for the lack of information. Prolly coulda had an answer by now with a little more work on my part.
Old Nov 18, 2003 | 01:59 PM
fast93accord's Avatar
look under the passanger side dash for the 2 pin blue connector. Put a piece of wire or paperclip into the connector to short it.
Old Nov 18, 2003 | 05:28 PM
Default Re: Checking timing, quick question (fast93accord)
ok thanks for everyone's help.
I checked the timing and I dont think it could be more dead on. I have replaced spark plugs and dizzy cap and rotor. So tommorrow I'm gonna head out and get some new NGK spark plug wires. Couldn't hurt. I thought about retarding the timing a bit to try to eliminate the pinging but I want to put in the wires to make sure I'm not just compensating for another part not working correctly.
After that I will see about changing the timing.
Anyway thanks for your help. (if anything is wrong with the thought process above feel free to set me straight)
hybridej7
Jul 26, 2005 11:14 AM
S2KP
Apr 7, 2004 08:26 PM
speedaccordinly24
Apr 20, 2003 08:56 PM
C4wrx
Feb 6, 2002 07:08 AM
fso_BamBam
Aug 21, 2001 01:50 PM
