Final Checklist before i go to the mechanic (helms manual owners please look!)
I will be taking the 94 integra to the mechanic tomorrow to do my auto to manual (96 gsr) transmission swap. Here's what i have, please let me know if i'm missing anything.
1. 96 GSR tranny
2. OBD 1 P75 ECU
3. ITR Shift Linkage (with shifter and civic ****)
4. Master Cylinder w/ reservoir
5. Slave Cylinder
6. Hydraulic Lines
7. Clutch/flywheel setup (pressure plate, Exedy clutch disk, flywheel, and fork)
8. Bolts for clutch/flywheel
9. New throw out bearing
10. OEM front and rear tranny mounts
11. Place Racing Top Tranny mount
12. ITR 5speed starter
13. Full manual pedal set (clutch, brake, gas pedals)
If I'm missing anything, post, pm, or AIM (nickispinoy) me. Thanks.
Modified by jdmintegra1994 at 8:35 PM 11/18/2003
1. 96 GSR tranny
2. OBD 1 P75 ECU
5. Slave Cylinder
6. Hydraulic Lines
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integra707 »</TD></TR><TR><TD CLASS="quote">You'll need a shift lever.
Won't you also need a manual center console? New shiftknob?
Thats all a given...
Sounds good to me... Goodluck!
From: You can be my wingman anytime...., Las Vegas, US
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 631 Teggy »</TD></TR><TR><TD CLASS="quote">
Sounds good to me... Goodluck!</TD></TR></TABLE>
I assumed, figured I'd mention just in case.
Alot of times the details we overlook are the most obvious.
Shift lever is on the shift linkage already...i have a civic shift ****...and no, you don't need a manual center console. It's exactly the same shape as the automatic
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D_TY3 »</TD></TR><TR><TD CLASS="quote">looks like everything is almost there
you will need the manual stiffner and the flywheel cover as well</TD></TR></TABLE>
what are those?
what are those?
-jacob-
Transmission & Drivetrain
Oct 31, 2008 03:57 PM
byronl
44
Apr 11, 2006 03:53 PM
