215/50/15 in 6.5?
Old Nov 17, 2003 | 10:51 PM
tangb2023
Guest
Posts: n/a
Default 215/50/15 in 6.5?
anyone ever try 215 /50/15 with a 15x6.5 inch rim.. kuhmo has 711 h rated for 44 bucks..the tread with is 8.9". i am think with more meat on the ground i would be better off with H instead of a 205 v rated with about 8.2'' or so on the ground with half of the price?? just want know if it would rub??
Old Nov 17, 2003 | 11:11 PM
mantic6t9's Avatar
Default Re: 215/50/15 in 6.5? (tangb2023)
I would go no more then a 205 on a 6.5in wide rim.
Old Nov 17, 2003 | 11:49 PM
Tad's Avatar
Tad
Default Re: 215/50/15 in 6.5? (mantic6t9)
you can definetely hang with 215 on a 7" tho
Old Nov 18, 2003 | 12:18 AM
OSX2000's Avatar
Default Re: 215/50/15 in 6.5? (Tad)
So 215/50/15 over a 15x7 would be fine?
Old Nov 18, 2003 | 04:58 AM
BERT-O's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tad &raquo;</TD></TR><TR><TD CLASS="quote">you can definetely hang with 215 on a 7" tho</TD></TR></TABLE>
I agree
Old Nov 18, 2003 | 06:44 PM
tangb2023
Guest
Posts: n/a
i know that a 215 should go with a 7'' wide rim..the quesrion is anyone ever tried it with a 6.5''..and what are the technical side to this..would the bead hold up??would there be over steer in cornering etc.??thanks for the replys though...keep em comming..
Old Nov 18, 2003 | 06:56 PM
WangChung's Avatar
worsth thing that can happen is ur tire blows due to the bead giving way and u spin into a wall doing 80. i have no idea if itll work, time to "shleppinside"
Old Nov 18, 2003 | 07:21 PM
Chris y0!'s Avatar
Default Re: 215/50/15 in 6.5? (Mugatu)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mugatu &raquo;</TD></TR><TR><TD CLASS="quote">worsth thing that can happen is ur tire blows due to the bead giving way and u spin into a wall doing 80. </TD></TR></TABLE>
not possible.
215 on a 6.5 will WORK, but it will rub.
but since your getting POS kumho 711s anyway, an extra 10mm of tread wont make a difference.
Old Nov 19, 2003 | 04:39 AM
WangChung's Avatar
Default Re: 215/50/15 in 6.5? (Chris y0!)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris y0! &raquo;</TD></TR><TR><TD CLASS="quote">
not possible.
but since your getting POS kumho 711s anyway, an extra 10mm of tread wont make a difference. </TD></TR></TABLE>
i was joking about that, just to letcha know.
Old Nov 19, 2003 | 05:21 AM
Mike_C's Avatar
You'll have rub issues, stick with 205s.
hondayute
Jan 26, 2008 11:39 PM
Import Prelude
May 13, 2007 04:28 PM
TheNasty0ne
Feb 17, 2006 11:25 AM
bdicustoms
17
Feb 19, 2004 06:19 PM
bearboy80
15
Dec 11, 2003 10:07 AM
