spring rate question
hey guys
im asking this question for my friend. he has a 95 del sol and the car came with skunk2 coilovers with tokico illumnias. my question is we took a look at the coilovers and the front and rear springs have the same spring rate (reads: 0700.250.006) could this be a problem with the cars handeling and ride comfort?
thanks
thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pr0jectezek1el »</TD></TR><TR><TD CLASS="quote">what if my friend made his shocks a little more stiffer would that make the car less bouncirer?
thanks for the relpy</TD></TR></TABLE>
yeah, what shocks does he have??
deffinately needs to upgrade
0700.250.006
i am 90% sure that designates a 7inch spring, 2.5" diameter, 6kg-mm spring.
the codes on my eg springs are 0700.2.50.006 and 0700.2.50.008. the 008's are a tad taller, about .2".
6kg/mm = 336lb/in, 8kg/mm = 448 lbs/in.
the springs for dc are 0700.2.50.010.
10kg/mm = 560lbs. this correlates with the springrates of 10k/8k which the integra is supposed to have. (560/448)
