Does anyone know how to check for CELs on these new civics? I have a new si...
Old Nov 17, 2003 | 04:46 PM
Battle Mike's Avatar
Default Does anyone know how to check for CELs on these new civics? I have a new si...
I was reading through my service manual, and there is a read out of MIL's (Malfunction Indicator Lamp). Now if there is a read out and it shows the number of flashes next to each detection...there's got to be a way. So I look at the bottom and it says when it's lit, you can jump the SCS (Service Check Signal) with a Honda PGM Tester...all a PGM tester is, is a connector that jumps a connection..just like using a wire that I would use for my previous civic (97 EX). So then I tried looking through to find this SCS..only thing I've come across so far is the wire, it's pin number 29 in connector 31P E of the ecu. I found the wire, but it's getting me all confused. I'm used to finding a connector then jumping it with a wire...like I did with my older car. But this is a wire going into a connector to the ecu...if I take out the connector the cel, of course goes away. So I'm not sure if I need to splice into the wire or not, or follow it back to where ever the hell it goes, and hopefully find a connector to jump.
For those interested in the CEL codes for the new si:
http://members17.clubphoto.com...phtml
Any help would be great...I've tried searching, but nothing for the new si's or rsx's
Old Nov 17, 2003 | 07:44 PM
andyep3's Avatar
Dang 02, I could have sworn I saw that discussion on here somewhere. Couldn't find it either, hopefully someone else can confirm there's a thread that exists...it might be in one of the "K20 into a EK/old chassis" type threads.
Old Nov 18, 2003 | 07:54 AM
yeah, I tried looking again, no luck.
I also tried taking a wire and jumping the ecu pin scs wire, and a ground wire. I thought for sure that would be it, but no luck. I just don't understand what it means by, jumping the scs wire...
Old Nov 18, 2003 | 08:17 AM
chunky's Avatar
you jump two pins on the obd II connector. I forget which ones, i'll look it up when i get home
Old Nov 18, 2003 | 05:09 PM
Default Re: (chunky)
ah, the obd II connector under the driver dash...a little to the right?
flip1199
Jul 29, 2005 02:48 PM
4b1z
Apr 13, 2005 09:17 AM
dingusjt
Nov 13, 2003 10:18 AM
T25 civic
Oct 6, 2002 02:11 PM
