99 jdm r in 98 ek???
Old Nov 17, 2003 | 03:56 PM
dose's Avatar
Default 99 jdm r in 98 ek???
i got a 99 integra type r swap(jdm) going in a 98 ek dx and im using the stock dx harness
from what i have read all i need to do is.....
1. add the vtec to a8
2.switch 3 wire iacv to 2 wire and that is it
3.add knock sensor
4.ckp sensor
5. switch a14 to a12
my questions aare??
1.do i have to do any wiring changes to the o2 sensors
2.will there be any loose/unused connectors
3.can some post a pic of where the iacv is on a jdm "r" motor
thanks
Modified by dose at 11:06 PM 11/18/2003
Old Nov 17, 2003 | 05:15 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: 99 jdm r in 98 ek??? (dose)
you will not be using the CKF sensor and the evap purge sensor ( fual rail vacuum switch) if i remember you need to switch the DX iac valve wire to where it would be in the 99 r harness. i did this on the last dx swap i did i cant remember the pins though.
Old Nov 17, 2003 | 06:25 PM
VTECVillain's Avatar
You will also have to wire up the Knock sensor and rewire the IAT since it's in the manifold on the ITR and the plug is different. Other than that it seems like you have everything covered.
Old Nov 17, 2003 | 06:41 PM
AL ASPIRATED's Avatar
u need to wire
VTEC solenoid (1 wire, terminal A8)
VTEC Oil Pressure (2 wires, terminal C15 and one ground)
Knock Sensor (1 wire, terminal D6)
IACV from 3 wires to 2 (move Pin A12 to A14, no orange wire USED)
CKF from 3 wires to 2, one wire is ground
IAT Change Plug and extend
O2 Sensors are fine, you would need to extend some wires if u want it to come out as clean as possible
hopefully i helped you somewat, sorry if its not enough
Old Nov 17, 2003 | 06:48 PM
Default Re: (JDMTyPeRHaTcH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMTyPeRHaTcH &raquo;</TD></TR><TR><TD CLASS="quote">VTEC Oil Pressure (2 wires, terminal C15 and one ground)
CKF from 3 wires to 2, one wire is ground</TD></TR></TABLE>
This is a JDM ITR which doesn't have either of those sensors.
Old Nov 17, 2003 | 07:15 PM
dose's Avatar
[QUOTE
[/QUOTE]
is this the ckp (crank sensor)
Old Nov 18, 2003 | 04:21 AM
Default Re: (dose)
CKF = Crank Fluctuation Sensor
CKP = Crank Angle Position Sensor
Old Nov 18, 2003 | 07:07 PM
dose's Avatar
any pics of the ckp or iacv on motor would be great
Old Nov 18, 2003 | 07:28 PM
Mr. Badwrench
the iac valve is on the back of the intake bout 3-4 inches long, aluminum block with a black motor attached to it. ad there is no CKF there is on the dx but not the r. it is the sensor under the bottom timming cover, and behind the timming belt sprocket. again this one isnt used.
Old Nov 18, 2003 | 07:37 PM
dose's Avatar
Default Re: 99 jdm r in 98 ek??? (boostedcivicsir)
i kno there is no ckf what about the ckp???
PICS PLEASE!!!
Old Nov 18, 2003 | 07:40 PM
Mr. Badwrench
the ckp or crank position top dead sensor is inside the distributor.
jordan2305
Oct 20, 2008 04:40 PM
B16b-EJ8
Apr 15, 2006 07:53 PM
alky350
Sep 7, 2005 01:27 PM
SC61HB
Jan 28, 2003 09:14 PM
