JE pistons and eagle rods
I sorta jump the gun and bought a set of je pistons and eagle rods made for a 1.8 integra 81.5mm bore, I have a b16a 81mm, I know all I need to do for the pistons is over bore .5 but what about the rods? will they be short enough to keep the 9.0.1 comp ratio, of the pistons in a b16 block, is the rods the same as b16?
It won't work unless you have the b18c1/5 or b16b crank. Any b-series rod will fit any b-series crank with the exception of the ones I just mentioned. In my case I wanted to see if I could get b16a rods/pistons for my b18c1, but I'd run into the same problem. I did the research before buying anything.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rudebwoy »</TD></TR><TR><TD CLASS="quote">will the b18 crank fit the b16 block without modification?</TD></TR></TABLE>
i dont think so,
the reason why i say this is because of the different heights of the two blocks. the block height of a b16 block is 263mm and the b18 block is 270mm
someone correct me if im wrong
i dont think so,
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ArinX »</TD></TR><TR><TD CLASS="quote">
i dont think so,
someone correct me if im wrong</TD></TR></TABLE>
yu need to take 1/2 the crank throw when you try to figure out the block height. so a b16a is going to be roughly203-204 ish and b18's are212-213ish. hth
i dont think so,
