del sol rear sway question
Old Nov 17, 2003 | 09:08 AM
pROjECt_D-sOL's Avatar
Default del sol rear sway question
does anybody know if del sol S's already have the mounting holes for the rear sways? i already have the lower control arms but im not sure if my car has the spots for it
Old Nov 17, 2003 | 09:53 AM
ill phil's Avatar
Default Re: del sol rear sway question (pROjECt_D-sOL)
Well look at the LCA's and see if the there are holes for the sway bar bolts. Pretty simple. Not sure by model, but its easy to tell by looking.
Old Nov 17, 2003 | 10:00 AM
eyeamvic's Avatar
No the S or Si don't have mounting holes for the rear sway bars. Many upgrade to the more beefier GSR lower control arms. I believe neuspeed makes something to work with the S or Si stock LCA's. Don't know of any others. And if you got some cash to spend, look into the SRR rear LCA, they're sexy
Old Nov 17, 2003 | 11:26 PM
ross1459's Avatar
the del sol DOHC VTEC has rear sways
Old Nov 18, 2003 | 12:26 AM
clm's Avatar
clm
Default Re: (ross1459)
The '96 and '97 Sis had sway bars, too. Considering the fact that Civics that didn't have sway bars didn't have mounting brackets, I would venture a guess that it's the same with del Sols. Easiest way is to look at the LCA.
Old Nov 18, 2003 | 03:35 AM
Default Re: (clm)
yea i already have the LCA's for the sway but my question is on the frame itself. are there holes there ready for th sway to be mounted?
Old Nov 18, 2003 | 06:48 AM
Default Re: (pROjECt_D-sOL)
BUMP
Old Nov 18, 2003 | 06:52 AM
SoloSol's Avatar
They are there. Im trying to do the same thing, I believe you MAY have to open up one of the holes a bit, I cant remember right now. But that should be easy if you get all the hardware....I would also suggest a Beaks,or BSQ kit.
Old Nov 18, 2003 | 07:10 AM
elevatethis's Avatar
Default Re: (SoloSol)
my 97 sol si has rear sway bars........
Mats_A_G
Sep 3, 2012 03:16 PM
724chris
Mar 20, 2011 06:21 PM
idriveadelsol7
Apr 13, 2005 09:25 PM
mafioso102
Jul 21, 2004 01:23 PM
