del sol...gsr sway bar question
New User
Well.....
I am currently looking for a gsr rear swaybar for my 93 del sol si....After searching I understand that i need:
obviously the sway bar
integra rear lca's
gsr endlinks
new bushings
is there anything else i will need? Also, i was thinking of using aftermarket lca's as long as I have to buy some. I saw these
and was thinking of getting them (mainly for the bling factor) w/ some upgraded bushings ( i heard the ones they come w/ dont fare too well)
So is my list complete? Also, can I used a lower tie bar w/ this setup. Thanks everyone.
integra rear lca's
gsr endlinks
new bushings
Re: del sol...gsr sway bar question (da935oul)
Seems kind of silly to buy $200 LCAs when you are using $50 worth of swaybar... but whatever.
EG/DC LCAs are the same measurements.
Re: del sol...gsr sway bar question (SkyeC)
I'd get the del Sol VTEC 15mm rear swaybar. Trust me from experience with both bars, the 15mm is definetly better!
Also, on the parts, make sure that you get the little metal insert that goes into the bushings for the endlinks and for the ends of the swaybar that bolts to the endlinks. When I swapped out my Integra 14mm swaybar for the 15mm del Sol VTEC swaybar, I had ordered new bushings and stuff, but they didn't come with the little round metal insert thingys, so make sure you get them! Fortunately the old bushings from the Integra swaybar had them so I just swapped them over. Good luck!
Re: del sol...gsr sway bar question (xavior66)
Oh, and one more thing. Should you decide to get the 15mm swaybar, make sure you get the corresponding "D" bracket bushings. The D bracket bushings for my 14mm rear swaybar had the number 14 stamped on both of them. The D bracket bushings for my 15 mm rear swaybar have the number 15 stamped on them. Go figure.
724chris
03-20-2011 06:21 PM
BLK JDM
01-23-2003 09:45 AM
