Installing a tach
Old Nov 17, 2003 | 05:27 AM
sshaikh01's Avatar
Default Installing a tach
Do i need to run a wire to the distributor or no.
Is this method correct.
black - ground
Red - 12V ignition power <--- Is that my ignition where the key goes ?
Green - RPM signal <---- I can find this under the hood by the driver side correct ?
White - Dash lights <--- where is that ?
Old Nov 17, 2003 | 05:37 AM
sohc_boy's Avatar
Default Re: Installing a tach (sshaikh01)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sshaikh01 &raquo;</TD></TR><TR><TD CLASS="quote">
Green - RPM signal &lt;---- I can find this under the hood by the driver side correct ?</TD></TR></TABLE>
blue wire with plug, driver's side right by the fire wall. no need to run to the dizzy, for lighting run it off your radio's iluminumation or anything convenient.
Old Nov 17, 2003 | 05:40 AM
zanthrax's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sshaikh01 &raquo;</TD></TR><TR><TD CLASS="quote">1 black - ground
2 Red - 12V ignition power &lt;--- Is that my ignition where the key goes ?
3 Green - RPM signal &lt;---- I can find this under the hood by the driver side correct ?
4 White - Dash lights &lt;--- where is that ?</TD></TR></TABLE>
1. almost any metalpart.
2. i'd use switched 12v. the easiest place to get that is at the sigaretlighter.
3. get your guagecluster out. it's got 2 harnasses in the back of it. RPM signal is the blue wire on the harness closest to your original tach.
4. while your gettting 12v from the lighter, get the dashlighting from the light in the ashtray.
Old Nov 20, 2003 | 04:30 PM
sshaikh01's Avatar
I had the tach hooked up and everything works fine.
I can't find a place to run the red wire from.
I ended up connecting it with the white one to the cruise control.
But i don't like this setup because the tach light is on everytime i start the car.
Is there a convienent place by the streeing wheel where i can run the 12v red wire to ?
Old Nov 20, 2003 | 04:59 PM
99blackcivicSi's Avatar
Maybe the dimmerswitch or the headlight handle (under the plastic) but if you always drive with your lights on like i do it won't make a differance.
Old Nov 20, 2003 | 05:10 PM
sshaikh01's Avatar
Default Re: Installing a tach (99blackcivicSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99blackcivicSi &raquo;</TD></TR><TR><TD CLASS="quote">Maybe the dimmerswitch or the headlight handle (under the plastic) but if you always drive with your lights on like i do it won't make a differance.</TD></TR></TABLE>
Which color wire would i use to run the power from the dimmer switch.
Old Nov 20, 2003 | 09:48 PM
sshaikh01's Avatar
ttt
Old Nov 21, 2003 | 03:18 AM
zanthrax's Avatar
the console with the cigarettelighter and ashtray on my EG8 has a harnass with 3 wires in it. 12v switch - dashlight - ground.
but you can get dashlight from any switch that lights up. or from the clock, that dims with the daylights on.
I took power for my indiglo gaugeoverlays directly from the circuitboard on the back of the cluster
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sshaikh01 &raquo;</TD></TR><TR><TD CLASS="quote">I had the tach hooked up and everything works fine.
I ended up connecting it with the white one to the cruise control.</TD></TR></TABLE>
Old Nov 21, 2003 | 12:53 PM
sshaikh01's Avatar
Default Re: Installing a tach (zanthrax)
the radio on the em1 is in the middle and all the wires are hard to get to.
I think i can run it the Cigarette lighter.
which color do i splice up for the power in the cig. lighter.
thanks zanthraz.
Old Nov 21, 2003 | 02:52 PM
zanthrax's Avatar
the switches on your dash are illuminated,right?
and those 4 wires from your tach are already running inside your dash, right?
your take out any 1 of those switches and measure what happens when you switch your lights on and off on every pin with a voltmeter/multimeter. you cant mess up anything.
one pin is bound to be black. hold the black pen from the meter to that and measure the others, one of the should only be giving 12v when the lighs are on.
splice the white wire from the tach into that one.
Old Nov 21, 2003 | 03:06 PM
redxbob's Avatar
Default Re: (zanthrax)
run the white wire from the tach to your switched pos wire on your dimmer switch if you dont know which one is swiched power get a test light turn your ignition on probe the wires,without crossing them while turnig the lights on and off the one that lights up the test light with the headlights on and shuts the test light off when the headlights are off is your wire tap into it just make sure you dont cut it
Old Nov 21, 2003 | 03:33 PM
sshaikh01's Avatar
Thank you Sir
r3dp1n0y
Aug 15, 2007 01:23 PM
zenon8890
Audio / Security / Video
Aug 1, 2007 11:32 PM
Junkyard2000
Nov 29, 2005 08:28 PM
kaoss_11
Jun 29, 2004 01:05 PM
99blackcivicSi
Apr 18, 2004 01:44 PM
