very stupid question
Old Aug 1, 2007 | 03:04 PM
zenon8890's Avatar
Default very stupid question
what is an electrotap? i'd like to see a pic of it too if possible
Old Aug 1, 2007 | 03:18 PM
B18C_EJ8's Avatar
Never heard of it... Take your pick of whatever you want it to be: http://www.google.com/search?s...earch
Old Aug 1, 2007 | 03:22 PM
zenon8890's Avatar
i'm about to install a field sfc and the diagram says that i should use eliectrotap for the ignition power and RPM signal
Old Aug 1, 2007 | 03:35 PM
suspendedHatch's Avatar
Default Re: (zenon8890)
Regardless of what the instructions say, you should solder your connections. The ignition can be tapped into at the distributer or the ignition harness. It's a thick black/yellow wire. The tach wire is a small dark blue wire at the distributer or the diagnostic plug.
If you don't have a distributer... well you should have told us what kind of car you have.
Old Aug 1, 2007 | 10:45 PM
zenon8890's Avatar
Default Re: (suspendedHatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by suspendedHatch &raquo;</TD></TR><TR><TD CLASS="quote">If you don't have a distributer... well you should have told us what kind of car you have.</TD></TR></TABLE>
i drive a honda crx with a d15b vtec swap, if u tell me what does the electrotap do for the wires(circut)
Old Aug 1, 2007 | 11:32 PM
projektCRX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by suspendedHatch &raquo;</TD></TR><TR><TD CLASS="quote">Regardless of what the instructions say, you should solder your connections. The ignition can be tapped into at the distributer or the ignition harness. It's a thick black/yellow wire. The tach wire is a small dark blue wire at the distributer or the diagnostic plug.
its no joke, correct me if im wrong, a tap is just an easy way of "tapping" into the desired wire with out cutting the actual wire, etc... but for almost anything that needs constant or consistant voltage or amperage. or whatever you want to make sure that you make a very good and solid connection, thats why he says to solder it... practice makes perfect...
climb_on
Sep 25, 2007 08:55 PM
tvman
Audio / Security / Video
Mar 26, 2006 09:33 AM
Dunc
Mar 20, 2005 12:26 PM
civic 16valver
Jul 1, 2004 07:23 AM
JDMmaster
May 7, 2004 08:36 PM
