will any of the skunk2 cams work for a jdm d15b vtec?
Old Nov 16, 2003 | 11:42 PM
South Bay Surfer's Avatar
From: South Bay, Torrance/Carson, CA, United States
Default will any of the skunk2 cams work for a jdm d15b vtec?
...and what will be the expected gains from this motor. becuz I read somewhere that this motor already has an aggressive cam.
Old Nov 17, 2003 | 09:23 AM
Default Re: will any of the skunk2 cams work for a jdm d15b vtec? (iluvjasmine)
bump
Old Nov 17, 2003 | 02:34 PM
HumanResource's Avatar
D15B SOHC VTEC runs the same P08 Head as the Z6 so yes they'd work
Old Nov 19, 2003 | 02:47 PM
-DC2-'s Avatar
it basically has a z6 cam. if anything it's only slightly more agressive than a z6.
Old Nov 19, 2003 | 02:58 PM
SOHC_MShue's Avatar
I doubt you would get much power because your cam is already pretty agressive. Eg6ajk dynoed at only 4whp with a zex 59300 cam on his d15b and I'm pretty sure the skunk2 stage 1 is a little bit less agressive than that.
Old Nov 19, 2003 | 03:48 PM
95dxhatch's Avatar
only 4 whp with a stage 2 cam? if this is true then **** the idea i had of getting the stage 2 cam for my d15b swap
Old Nov 19, 2003 | 03:53 PM
SOHC_MShue's Avatar
Default Re: (95dxhatch)
its probably because of the already agressive cam.
Old Nov 19, 2003 | 07:42 PM
blackeg's Avatar
Default Re: will any of the skunk2 cams work for a jdm d15b vtec? (SOHC_MShue)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC_MShue &raquo;</TD></TR><TR><TD CLASS="quote">I doubt you would get much power because your cam is already pretty agressive. Eg6ajk dynoed at only 4whp with a zex 59300 cam on his d15b and I'm pretty sure the skunk2 stage 1 is a little bit less agressive than that.</TD></TR></TABLE> i was gonna bring this up- u beat me to it.
dizzyek
Jun 21, 2006 11:48 AM
SOHCEK-Turbo
Mar 3, 2004 07:25 AM
creechrr
Nov 18, 2003 07:44 AM
blackeg
11
Sep 7, 2003 09:10 PM
95civicracer
Jul 30, 2003 11:02 AM
