Swap almost done, 1 problem though :(
Old Nov 16, 2003 | 07:45 PM
LHC's Avatar
LHC
Default Swap almost done, 1 problem though :(
on the hybrid garage page it doesnt show the pin out for the secondary air intake sensor so im like WTF?? can anyone tell me the correct pinout for this sensor...thanks
-JOE
Old Nov 16, 2003 | 08:51 PM
sol_1320's Avatar
Default Re: Swap almost done, 1 problem though :( (LatinoHatchCrap)
hope this helps
http://www.autoserve.8m.com/cg...2.jpg
Old Nov 16, 2003 | 09:23 PM
PHiZ's Avatar
Default Re: Swap almost done, 1 problem though :( (sol_1320)
Hrm, GSR swap? are you talking about the IAV (secondary intake runner solenoid)?
-PHiZ
Old Nov 18, 2003 | 12:29 AM
EKFerioHawaii's Avatar
Default Re: Swap almost done, 1 problem though :( (PHiZ)
OT: Latino, wow who's that chicken in your avatar?
Old Nov 18, 2003 | 05:05 AM
VTECVillain's Avatar
Which model/year car and ECU are you using? The OBD1 P72 ECU uses a 12V+ trigger for the IAB but the OBD2 P72 uses a negative trigger.
Old Nov 18, 2003 | 10:16 AM
ndogg's Avatar
Default Re: Swap almost done, 1 problem though :( (VTECVillain)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTECVillain &raquo;</TD></TR><TR><TD CLASS="quote">Which model/year car and ECU are you using? The OBD1 P72 ECU uses a 12V+ trigger for the IAB but the OBD2 P72 uses a negative trigger.</TD></TR></TABLE>
you got that backwards.
for USDM p72:
obd1 uses a negative trigger (you need to put the "ground" wire to a 12V
obd2 uses a positive trigger (ground the ground wire)
JDM:
obd1 uses a positive trigger
obd2 ???
mkeacura
Aug 26, 2013 11:07 AM
jimmy o.
12
Sep 2, 2008 04:58 PM
ATrin
18
Jul 31, 2006 05:38 AM
