P28 ecu on JDM ITR
Old Nov 16, 2003 | 06:42 PM
dohcvtecR's Avatar
Default P28 ecu on JDM ITR
I have a problem with my JDM ITR( swapped to my 97 gsr). The JDM ITR ecu I have is working fine but not the p28 mugen spec ecu. It's giving me engine code 22-vtec switch. If I have a problem with the vtec switch, shouldn't the engine light turn on with the JDM ecu also? Can you you guys help me fix the problem? Advice?
Old Nov 16, 2003 | 08:02 PM
R6Boy69's Avatar
Default Re: P28 ecu on JDM ITR (dohcvtecR)
this is just a guess but i think i might be right... i dont think the JDM itr ecu looks for the vtec pressure switch... but the usdm p28 does...
Old Nov 17, 2003 | 05:13 AM
kenji's Avatar
25 Year Member
Default Re: P28 ecu on JDM ITR (crXBoy69)
Run a jumper wire between the VTEC solenoid and VTEC PS wire to trick the P28 ECU into thinking there is a VTEC PS present. This will eliminate the CEL you are experiencing.
-kenji
Old Nov 17, 2003 | 06:04 AM
splitime's Avatar
Default Re: P28 ecu on JDM ITR (kenji)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kenji &raquo;</TD></TR><TR><TD CLASS="quote">Run a jumper wire between the VTEC solenoid and VTEC PS wire to trick the P28 ECU into thinking there is a VTEC PS present. This will eliminate the CEL you are experiencing.
-kenji</TD></TR></TABLE>
Yup, what he said. A helms comes in handy here to find the 2 pinout locations at the ecu where these are.
Old Nov 17, 2003 | 06:05 AM
976's Avatar
976
New User
Default Re: P28 ecu on JDM ITR (splitime)
Good info
Old Nov 18, 2003 | 10:35 AM
hondeducation's Avatar
hey kenji, your pm option doesn't work or is disabled... how much for a p28 w/ mugen program shipped? it'd be for my b20/vtec....
Old Nov 18, 2003 | 10:37 AM
splitime's Avatar
Default Re: P28 ecu on JDM ITR (hondeducation)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondeducation &raquo;</TD></TR><TR><TD CLASS="quote">hey kenji, your pm option doesn't work or is disabled... how much for a p28 w/ mugen program shipped? it'd be for my b20/vtec....
Check his profile and Email him.
moz92
Oct 1, 2009 11:55 PM
g_spek
Northern California (Sales)
Aug 20, 2009 04:37 PM
89D15CRXDX
Sep 29, 2007 12:54 PM
SCORPIONZZZZZ
Apr 22, 2005 01:24 PM
JinDIESEL
Aug 24, 2004 05:18 AM
