VTEC activation troubleshooting!
Old Nov 16, 2003 | 01:51 PM
SleepyEG's Avatar
Default VTEC activation troubleshooting!
I'm driving a 92 dx hatch with a B18C1 from a 95GSR..The swap has been running fine, the only wires I ran were Knock, and the 2 for the IAB's...I'm pretty sure at this point that VTEC is not engaging. This motor came from an integra I owned that was in an accident, and on the integra, with the exact same setup, just a different exhaust..(Comptech vs. Trust...shouldn't matter) The VTEC crossover at 5800 or wherever was very noticable in sound and feel. Now I hear the IABs(or what I think is the butterflies) at 4500, but no sound or feeling change at 5800ish..Suggestions?
~james
Old Nov 16, 2003 | 02:19 PM
mmuller's Avatar
Mad Scientist
Default Re: VTEC activation troubleshooting! (SleepyEG)
vtec kicks in at 4400, the secondaries at 5750
Old Nov 16, 2003 | 02:31 PM
SleepyEG's Avatar
Default Re: VTEC activation troubleshooting! (mmuller)
so if I'm hearing a loud change at 4400, that's VTEC...but there is another VTEC change higher up isn't there, same time as the IAB's? 5750 or wherever?
Old Nov 16, 2003 | 03:06 PM
mmuller's Avatar
Mad Scientist
no only one change, vtec at 4400 and then the secondaries, wich kinda sounds like vetc at 5750. maybe you wired the secondaries wrong?
Old Nov 16, 2003 | 04:37 PM
SleepyEG's Avatar
wow I feel dumb, I was always under the impression there were two crossovers, thanks for clearing that up...I thought I remembered seeing 3 sets of specs for cams and whatnot, but I guess I was wrong...anyway, how can I check if my IAB's are working properly?
Old Nov 16, 2003 | 05:29 PM
AL ASPIRATED's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mmuller &raquo;</TD></TR><TR><TD CLASS="quote">no only one change, vtec at 4400 and then the secondaries, wich kinda sounds like vetc at 5750. maybe you wired the secondaries wrong?</TD></TR></TABLE>
how do u wire the secondaries? which wires go where? THANKS
Old Nov 16, 2003 | 05:47 PM
mmuller's Avatar
Mad Scientist
how did you wire the secondaries?did you move a20 to a17 and gave 12v to ground wire from iab?
read this:
https://honda-tech.com/zerothread?id=631748
Old Nov 16, 2003 | 07:02 PM
dunkd's Avatar
i did the same swap into my car...
knock sensor - d3
IAB's - just switch a17 and a20
vtec solenoid wire - a4
vtec pressure switch (blk)- ground
vtec pressure switch (red? not the black one) - d6
u will hear and feel vtec @ 4400, then secondaries open at ~5700, you wont really hear anything, just feel it.
Old Nov 17, 2003 | 04:23 AM
SleepyEG's Avatar
Default Re: VTEC activation troubleshooting! (dunkd)
first of all, thanks to the other kid for the thread jacking, second....I followed the wiring advice of poison and hatch4ursnatch....so I don't think it's wired wrong, but I did check it out last night, and the IAB's are just always open! So I guess I'm not losing power up top, but I'm losing low-end torque..and definately that explains the gas mileage I've been getting
~james
Old Nov 17, 2003 | 06:47 AM
mmuller's Avatar
Mad Scientist
give them power to see if they move.
Danielsb20crx
24
Jul 5, 2009 01:37 AM
coup3y
Mar 14, 2009 03:12 PM
Dc2 Joe
Jul 5, 2005 09:26 AM
xvracing
May 1, 2004 01:49 PM
fast4w$
Sep 26, 2003 06:36 PM
