DO I NEED TO RESET MY ECU?
I JUST INSTALLED A INJEN SHORT RAM, SOUNDS BADASS AFTER VTEC I MIGHT ADD
BUT I WANNA KNOW IF I NEED TO RESET MY ECU AND IF SO
HOW THE HELL DO I DO IT
PEACE
PEACE
You also have to perform the "idle relearn procedure." Let the car idle with the A.C. off and nothing on with the doors closed for at least 5 minutes...This should be done anytime you add a perfromance piece of equipment.
Also don't forget to re-program your drivers side auto up/down window...Just hold it completely down until the window is all the way down and then do the same raising it up. It should work
Blacknight117
Oct 28, 2011 07:24 PM
