easiest way to reset ECu
Old Sep 23, 2002 | 12:47 PM
Grimm's Avatar
Default easiest way to reset ECu
Well like it says... Will disengaging the battery do the trick or do I need to do something else... Unplug ecu from car?
Old Sep 23, 2002 | 12:51 PM
builthatch's Avatar
MiG-21 superfan
Default Re: easiest way to reset ECu (Grimm)
easier way, pull the fi/ecm fuse in the underhood fusebox
Old Sep 23, 2002 | 12:55 PM
Grimm's Avatar
Default Re: easiest way to reset ECu (builthatch)
thanks...
94gsr's Avatar
It's the 7.5a fuse. You only need to pull it for 30 seconds. Put it back in, start the car & let it idle until the fan comes on twice.
Old Sep 23, 2002 | 12:57 PM
Spade's Avatar
Default Re: easiest way to reset ECu (94gsr)
Or 10 minutes. If your radiator is too big for your engine
Old Sep 23, 2002 | 01:04 PM
ViZ's Avatar
ViZ
Default Re: easiest way to reset ECu (Spade)
if your car is surging in idle will your ecu reset properly?
(i have a few things left to troubleshoot on the idle so i dont need comments on that )
Old Sep 23, 2002 | 01:09 PM
Spade's Avatar
Default Re: easiest way to reset ECu (ViZ)
Yes and no. It will be able to get rid of all of the old codes and then will generate new ones once the bad devices talk to the ECU.
Old Sep 23, 2002 | 01:10 PM
94gsr's Avatar
As long as you're not throwing a code, yes.
Slo_Accord
Nov 10, 2007 12:47 AM
ieatrice
Mar 16, 2004 12:48 PM
FroggyR
Mar 10, 2002 05:36 PM
illusion
Feb 18, 2002 03:02 PM
