F22 Crank in H22
Old Nov 15, 2003 | 06:36 PM
jdmcivicferio's Avatar
Default F22 Crank in H22
I heard if you put the crank from a F22 Accord 90-93, and the rods. It wil give more displacement, as if doing an h23 crank and rods, is this true
thanks
Old Nov 15, 2003 | 06:48 PM
satan_srv's Avatar
Default Re: F22 Crank in H22 (jdmcivicferio)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmcivicferio &raquo;</TD></TR><TR><TD CLASS="quote">I heard if you put the crank from a F22 Accord 90-93, and the rods. It wil give more displacement, as if doing an h23 crank and rods, is this true
thanks</TD></TR></TABLE>
h23 crank = f22 crank
Old Nov 15, 2003 | 07:24 PM
ViZ's Avatar
ViZ
Default Re: F22 Crank in H22 (satan_srv)
ok this is interesting, i have heard of the h23 being done many many times but the f22 crank will work also? what else has to be changed to make this happen because i have an f22 sitting around right now.. i will search but a quick bit of information would help
Old Nov 15, 2003 | 09:39 PM
satan_srv's Avatar
Default Re: F22 Crank in H22 (ViZ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ViZ &raquo;</TD></TR><TR><TD CLASS="quote">ok this is interesting, i have heard of the h23 being done many many times but the f22 crank will work also? what else has to be changed to make this happen because i have an f22 sitting around right now.. i will search but a quick bit of information would help</TD></TR></TABLE>
As far as I know nothing. Think about how the engines were deveopled. The 85mm bore F22 came in 1989-90, 95mm stroke 141.5ish rods. Then they developed FRM and used the same F22 structure to make the H23. THen they threw on VTEC and destroked it to get the H22.
Long story short all aftermarket rods for the H23 are the same as the F22, same crank same everything. check part numbers if you want I guess.
Old Nov 15, 2003 | 11:20 PM
so essentially all I would have to do is add in the crank and the rods from the f22 I have, and then I would have a h23vtec motor..... pretty crazy. But I am guessing I would have to resleeve it and all that blah blah but at least I no I can have a h23 pretty easy
Old Nov 16, 2003 | 10:33 AM
93 VTEC's Avatar
H23 and F22 crank and rods are the same P/N.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmcivicferio &raquo;</TD></TR><TR><TD CLASS="quote">so essentially all I would have to do is add in the crank and the rods from the f22 I have, and then I would have a h23vtec motor..... pretty crazy. But I am guessing I would have to resleeve it and all that blah blah but at least I no I can have a h23 pretty easy</TD></TR></TABLE>
You wouldn't need to resleeve to make a 2.3VTEC, just use stock pistons
Old Nov 16, 2003 | 12:51 PM
LudeyKrus's Avatar
Default Re: F22 Crank in H22 (93 VTEC)
Yep, the F22 crank and rods are the same as the H23.
For more info on this swap, check this post:
https://honda-tech.com/zerothread?id=510617
Old Nov 16, 2003 | 09:51 PM
Default Re: F22 Crank in H22 (LudeyKrus)
just out of curiousity, if I wanted to put in prelude Type S pistons, would I have to resleeve it then?
my plan was going to be use the crank and rods I have, then buy some JDM type s pistons...
thanks for the help guys!
rmartin708
Jul 28, 2009 11:14 AM
MaddDogg49
Jul 18, 2006 01:41 PM
MadCityLude
Jul 14, 2006 03:44 PM
Mr Rex
Jun 17, 2006 06:23 PM
lilbill3554
Nov 14, 2003 12:27 PM
