HELP!!1 VTEC is not OPENING!!!
Tonight In my brother's EM1-00 Si we were on the highway and VTEC was working fine,but then later on we being tailgatd and the engine would not crack VTEC we took up 2 6500 rpm and still no sign of VTEC....what the hells going on? I need some major help cause we can't afford to take it to the HONDA dealership what can be causing the VTEC not to engage.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1ntensiveVTECivic »</TD></TR><TR><TD CLASS="quote">Yes, but its has been on for a while because of the gutted cat.</TD></TR></TABLE>
Check to see if it is throwing code 21 or code 22
vtec measures alot of other things too though right, coolant temp, oil pressure/level. im not sure about the other variables but it could def. be a few more things.
no only oil pressure but vtec would still engage, unless there is really low oil pressure. pull the cannister off and see if u broke the spring or spun the silinoid pressure valve. x3 10mm and 10 min.
..ISawUL00k...
DAM
Ayes
..ISawUL00k...
DAM
Ayes
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ISawUL00k »</TD></TR><TR><TD CLASS="quote">Check ur ECU connections and Vtec line to silinoid maybe barrow a friends ECU..
How Do You Brake VTEC
... ISawUL00K
you got some fucked up english.
... ISawUL00K
</TD></TR></TABLE>you got some fucked up english.
xtreme-customz
18
Dec 1, 2005 07:51 PM
