Jerky, stagnate acceleration...
Sushi Buffet Champion
I have a B20vtec, when I accelerate almost half the time it jerks or is stagnate(barely pulls). Also jerks when shifting, it's hard to do a smooth shift.
Funds were low after the swap, so it's still running on old/used B20 spark wires and plugs. The distributor is from a 99 Si and rotor hasn't been changed. Still running on the B20 injectors.
ECU is P73, fuel pump is 99 Si. Running on a stock exhaust system.
Please help. TIA.
Please help. TIA.
I think thats your problems right there!!
Someone mentioned that the B20 block and the vtec head causes the oil pump sensor to cause the jerkiness and that I should switch to a P28 ecu. Can anyone confirm that?
blazin99si
Aug 5, 2004 03:46 PM
