Jerky, stagnate acceleration...
Old Nov 15, 2003 | 04:27 PM
GapxGuy's Avatar
Sushi Buffet Champion
Default Jerky, stagnate acceleration...
I have a B20vtec, when I accelerate almost half the time it jerks or is stagnate (barely pulls). Also jerks when shifting, it's hard to do a smooth shift.
Funds were low after the swap, so it's still running on old/used B20 spark wires and plugs. The distributor is from a 99 Si and rotor hasn't been changed. Still
running on the B20 injectors.
ECU is P73, fuel pump is 99 Si. Running on a stock exhaust system.
Please help. TIA.
Old Nov 15, 2003 | 04:32 PM
K20EG's Avatar
Default Re: Jerky, stagnate acceleration... (GapxGuy)
since you got the p73 in there ...you prolly got the oil pump that goes with that ecu as well
if im not mistaken its the B-20 block and the vtec head throws off that oil pump sensor causing that jerkiness your talkin about
get a jumper harness and a chipped p-28
Old Nov 15, 2003 | 04:40 PM
GapxGuy's Avatar
Default Re: Jerky, stagnate acceleration... (K20EG)
The B20 oil pump is the same as the P73, so you're saying I'll have to change ECUs? Are you positive about this? If so are they alternatives to this problem?
Old Nov 15, 2003 | 04:44 PM
K20EG's Avatar
is the chek engine light on?
i would try another ecu and see where it takes you
rarely unless there totally messed up ..plug wires and plugs wont cause that
Old Nov 15, 2003 | 04:48 PM
GapxGuy's Avatar
CEL is not on, so it's not throwing any codes. So you don't think it's fuel delivery or spark management huh? You think the problem is coming from the ECU then? I was hoping it was just dirty injectors or something. If I dynoed, the powerband would be VERY zigg-zagged.
Old Nov 15, 2003 | 04:56 PM
K20EG's Avatar
What year is your car ?
Old Nov 15, 2003 | 04:59 PM
GapxGuy's Avatar
It's a 97 hatch with a 98 ITR ecu.
Old Nov 15, 2003 | 05:02 PM
K20EG's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GapxGuy &raquo;</TD></TR><TR><TD CLASS="quote">It's a 97 hatch with a 98 ITR ecu.</TD></TR></TABLE>
yea i would seriously look into getting another ecu i know exactly what your expeirencing and the car will be night and day difference with a jumper harness and a chipped p-28.
Old Nov 15, 2003 | 05:03 PM
GapxGuy's Avatar
If you're that positive about it, I will look into that asap. Any other suggestions? Thanks for your help.
Old Nov 15, 2003 | 05:07 PM
K20EG's Avatar
Im pretty damn sure..LOL
if you rev your car and try to hold it at or around 3k and the engine surges a little bit on its own ...its the ecu in this case
Old Nov 15, 2003 | 05:12 PM
GapxGuy's Avatar
3K in neutral? What do you mean by surge?
Old Nov 15, 2003 | 05:16 PM
K20EG's Avatar
just try to hold the car @ 3k rpm
the rpms wont hold steady on and off load ...thats what causes the jerkiness
Old Nov 15, 2003 | 05:20 PM
GapxGuy's Avatar
Well, it's pretty steady reving to 3k and holding it there in neutral. It's just the acceleration, it feels like it's killing my engine mounts.
Old Nov 15, 2003 | 05:21 PM
K20EG's Avatar
but when you step on it the car feels cool right
Old Nov 15, 2003 | 05:26 PM
GapxGuy's Avatar
Reving in neutral is no problem, it's smooth. It's regular accelteration to punching it, that's when it starts jerking. So if I want it to be smooth, my foot has to glide easy on the pedal when gassing it.
potatointegra01
Jan 20, 2016 08:09 AM
MI4$DC5
Jul 19, 2008 12:16 PM
GapxGuy
Nov 15, 2003 05:41 PM
GapxGuy
Nov 15, 2003 05:07 PM
