Special tool for flywheel
i did a search and found out some people use flatheads and some guy used a battery tie down.
http://courtneyeg9.streetracin....html
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedcivicsir »</TD></TR><TR><TD CLASS="quote">i think he means this one. it isnt needed but if you want it is 64.00 on snap ons page.
I got somethin similiar to that ...i got it from Honda..the hex doesnt go deep enough for most crank pulleys ....arrrgg
just use a open end box wrench,about 17mm.then use 2 bolts,one on the flywheel and one on the block,put the wrench between the 2 bolts.easy for cheezy my sleezy neezy!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Emerika »</TD></TR><TR><TD CLASS="quote">just put a ratchet on the crank pulley and have someone hold it....or a flathead in the teeth and rest the arm on a dowel pin</TD></TR></TABLE>
i'm probably going to try this method. thanks for the help
Yep, I've done this soo many times. Make sure you use a pretty big flathead though.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sac »</TD></TR><TR><TD CLASS="quote">I normaly just put a big breaker bar on the pully side and let the ground hold the force when taking em off. Can even do it by yourself. Pretty simple</TD></TR></TABLE>
I do that when the engine's on the ground, but not when on a stand. I guess you could put a big pipe on it still
Just have someone else hold the crank with a breaker bar and 19mm while you take the flywheel of...Or put the socket on the crank and rest the bar or ratchet so it hits the floor or something so it wont spin...no need to spend $60
HTLuver
12
Feb 26, 2007 01:20 PM
