Axle need to be removed?
Old Nov 15, 2003 | 02:46 PM
invboost's Avatar
Default Axle need to be removed?
Hey guys, im about to drop my tranny in order to change my clutch but, i dont have a 32 mil for the axle nut...is there a way to drop the tranny without the axle having to come off?
Old Nov 15, 2003 | 03:01 PM
Unjockable's Avatar
New User
Default Re: Axle need to be removed? (invboost)
i'm pretty sure it has to come out. the axle and halfshaft is connected to the tranny.
Old Nov 15, 2003 | 03:39 PM
mantic6t9's Avatar
Default Re: Axle need to be removed? (Unjockable)
Hey man. You can rent the 32mm axle socket at AutoZone. When you return it you get your money back..
Old Nov 15, 2003 | 04:12 PM
lithium00's Avatar
make sure that you get the 3/4" 32mm socket and the 3/4" breaker bar. The 1/2" 32mm socket doesnt cut it.
Old Nov 15, 2003 | 04:49 PM
DumpedSi's Avatar
Default Re: (lithium00)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lithium00 &raquo;</TD></TR><TR><TD CLASS="quote">make sure that you get the 3/4" 32mm socket and the 3/4" breaker bar. The 1/2" 32mm socket doesnt cut it.</TD></TR></TABLE>
Ive dont a ton of axels and the 1/2 inch ratchet has worked for me just fine. Im pretty sure you need to remove the axels and even if its not needed it would make the job a whole lot easier...
Old Nov 15, 2003 | 04:53 PM
JDM-97CX's Avatar
Default Re: (Slammed Si)
u need to remove your brain because you dont use it any way
Old Nov 15, 2003 | 04:57 PM
99blackcivicSi's Avatar
WTH! are you talking about i do every honda i have ever worked on with my 1/2" breaker bar and my 32 mill
Old Nov 15, 2003 | 05:27 PM
underpressure02's Avatar
I just removed both of those nuts for each side this weekend when I was doing some maintaince on my car. I did not even know it was 32MM I just used a big amercian socket and my impact wrench. It came right off. You are supposed to tq those nuts to 135ft/lb by the way. If you have a big enough american socket you should be fine.
Old Nov 15, 2003 | 08:14 PM
civicrtype's Avatar
what motor? if its a sohc u dont need to remove em from the hub just take em out of the tranny and move them aside,
if its a dohc u can just remove the passenger side one from the tranny and then just slide the trans out, it might take a little tugging, if it wont come out u can remove the drivers side out from the halfshaft and then unbolt the halfshaft.
You don't need to take out the axles from the HUB.
Old Nov 15, 2003 | 10:31 PM
salbaje's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by invboost &raquo;</TD></TR><TR><TD CLASS="quote">Hey guys, im about to drop my tranny in order to change my clutch but, i dont have a 32 mil for the axle nut...is there a way to drop the tranny without the axle having to come off?</TD></TR></TABLE>
there is a way to drop your tranny without taking out the axle from the hub. But regardless you need to take off the axles from tranny and same for intermediate shaft. you can unbolt the lower control arm and put it aside
Old Nov 15, 2003 | 11:35 PM
civicmon's Avatar
Default Re: Axle need to be removed? (salbaje)
I just dropped and re-installed my tranny today and I left them in there, undo the lower ball joint nut, and pull it out like you were to replace it and leave it in there.
The problem I had though, is that they got in the way constantly and were a pain, so beware..
88aeFC3S
Dec 23, 2010 07:43 AM
project91crxsi
Aug 21, 2009 05:56 PM
FlyZlow
18
Jan 5, 2005 08:21 AM
DXRiCE98
Oct 17, 2003 12:59 PM
Red_Si
Sep 23, 2003 04:03 PM
