difference in f22 vs f23
Old Nov 15, 2003 | 11:29 AM
fastludeh22's Avatar
Default difference in f22 vs f23
was wondering if it was the crank or the bore, that add that .1 of displacement.
Old Nov 16, 2003 | 09:08 AM
Default Re: difference in f22 vs f23 (fastludeh22)
any one?
Old Nov 17, 2003 | 06:23 AM
v4lu3s's Avatar
RTFM
slightly larger bore and longer stroke.
Old Nov 17, 2003 | 11:30 AM
Default Re: (v4lu3s)
so it does have a longer stroke...anyone know the stroke.
i also need to know the main and rod journals size.
the reason is i am building a stroker h-series. people use the h23 crank so i started there. then i found out that f22 uses the same crank as the h23. so then i started thinking if f22 crank works, how bout f23. i figure if the main's are the same size it can be done.
once i know the stroke i can figure the custom piston pin hight, cause i plan on using h22 rods to keep the r/s ratio as good as possible.
Old Nov 17, 2003 | 12:44 PM
Nick H's Avatar
New User
Default Re: (fastludeh22)
http://www.accordinglydone.com...ies=F
that should help you out quite extensively....
F23: bore = 86mm
stroke = 97mm
F22: bore = 85mm
stroke = 95mm
i am doing a similar build, but am using an f22 crank...it seems to be working just fine...i'm building for boost though, so i'm using brand new oem h23 pistons and rings instead of rebushing the h22 type s pistons and going for high compression stroker...good luck with the build...
Old Nov 17, 2003 | 05:29 PM
FDAccord's Avatar
A guy I know who was making stroker kits for the H23 used F22 parts for his.. So I'm guessing the F22 would be wise..
Old Nov 18, 2003 | 08:31 PM
Default Re: (Nick H)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nick H &raquo;</TD></TR><TR><TD CLASS="quote">http://www.accordinglydone.com...ies=F
F23: bore = 86mm
stroke = 97mm
F22: bore = 85mm
stroke = 95mm
i am doing a similar build, but am using an f22 crank...it seems to be working just fine...i'm building for boost though, so i'm using brand new oem h23 pistons and rings instead of rebushing the h22 type s pistons and going for high compression stroker...good luck with the build...</TD></TR></TABLE>
thanks,
im going boost myself also. according to that, the f23 is sohc, will this make a difference. i wouldnt think it would matter for the crank.
also that doesnt tell me the main sizes, which is very important. i dont think i can use h22 rods w/that crank, there isn't enough room on the pistons to move it that much. maybe ill use the h23 rods.
what is the forumla for figuring r/s ratio. also for dis-placement. i know i could fig it out, but im being lazy.
Old Nov 18, 2003 | 09:57 PM
also check out this post also:
https://honda-tech.com/zerothread?id=682261
Old Nov 19, 2003 | 04:45 AM
v4lu3s's Avatar
RTFM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fastludeh22 &raquo;</TD></TR><TR><TD CLASS="quote">
thanks,
what is the forumla for figuring r/s ratio. also for dis-placement. i know i could fig it out, but im being lazy.</TD></TR></TABLE>
for main sizes you may want to find someone with a helm manual or buy one yourself if you won the engine.
and for figureing the r/s ratio....the forumla is right in front of you and you already typed it out once.
and for the rods....h23a1 rods=f22a/b rods
LudeyKrus
Mar 15, 2010 01:37 PM
lrayford
Sep 3, 2009 01:55 PM
rmartin708
Jul 28, 2009 11:14 AM
fastludeh22
Nov 20, 2003 09:08 AM
Meateater
Nov 3, 2001 03:14 PM
