fan assembly
I'm putting in a new fan assembly that I ordered to replace the radiator fan (the old one was making noises and a shop said that the motor went bad). I cant pull it out because of a coolant house going over the top, so I'm guessing I'm going to have to drain the coolant and then disconnect the hose. Is this correct or can I disconnect the hose without having to drain the coolant? I also tried to find the drain plug for the coolant and couldnt seem to find it. Any help is greatly appreciated! Thanks!
hmmmm....the drain plug would have to be on the bottom of the radiator.
although u might be able to just pull the hose off and hold it up. Make sure u have a cup or somethin just in case it starts flowin. I dont think it should be too bad.
BoostedSi
Feb 6, 2003 07:36 PM
