compression test - what's bad?
Old Nov 15, 2003 | 09:02 AM
tilt's Avatar
Default compression test - what's bad?
My friend's crx si has been running rough so I did a quick compression test. came out 180 180 180 0. The spark plug on the bad cylinder was fouled and covered in oil, the rest were clean. Coolant is clean. I'm guessing itd have to be a burnt valve to cause such a loss in compression... do you guys have any ideas what else it could be? tia
Old Nov 15, 2003 | 10:10 AM
MrTodd's Avatar
Default Re: compression test - what's bad? (tilt)
It's most likely a jacked up valve (bent/burnt). Obviously the only way to find out for sure is to pull of the head... Good Luck!
PS - keep in mind the D15B2 (Dx) heads are almost exactly the same as the Si head, except for the camshaft. Incase you decide to replace it....
Old Nov 19, 2003 | 02:40 PM
tilt's Avatar
Default Re: compression test - what's bad? (MrTodd)
I pulled the head. you were right, burnt exhause valve. thanks
MikeD21
Engine Machining & Assembly
14
Jan 3, 2019 10:54 AM
keith1993may
12
Jul 10, 2013 04:18 PM
ozh_hawaiian
Jun 24, 2011 12:03 AM
hutcho3
Apr 11, 2011 06:54 PM
civic-one
Apr 6, 2011 08:02 AM
