dammit. timing belt snapped during freeway
Old Nov 15, 2003 | 04:08 AM
F120man's Avatar
New User
Default dammit. timing belt snapped during freeway
god dammit. i was cruisin home from my gf's 15 miles away from home. bout 2 miles into the freeway while cruisin 70mph. i heard a pop, and my car felt weird. stepped on the pedal, got no power . damn, so i pulled over, popped the hood and wha-la. my belt has snapped! **** i just bought the belt 2 months ago, and put less than 500 miles on it. wtf! on top of that, AAA wont let me use my dad's membership cause he wasnt present at the time, so i ended up paying 80 bucks for the hook up and 5 bucks for every mile home, which came out to 155 dollas. anyone know what the possible reason for my belt to snap like that?
Old Nov 15, 2003 | 05:01 AM
TurboSam's Avatar
Default Re: dammit. timing belt snapped during freeway (F120man)
did u replace the water pump too?
Old Nov 15, 2003 | 11:16 AM
F120man's Avatar
New User
Default Re: dammit. timing belt snapped during freeway (Turbo Sam)
yeah i changed the belt and the water pump at the same time.
Old Nov 15, 2003 | 01:32 PM
BoostedH23a1's Avatar
yea miines snaped 3-4 times now... whenever they make a nice aftermarket one.. ill buy it
Old Nov 15, 2003 | 01:40 PM
dvsracergirl's Avatar
Default Re: dammit. timing belt snapped during freeway (BoostedH23a1)
they make an aftermarket one. Power Enterprise makes a kevlar re-inforced belt. I put it on my car....very nice.
Old Nov 15, 2003 | 03:28 PM
dankbudz11357's Avatar
Default Re: dammit. timing belt snapped during freeway (BTgirl)
doesn't toda also make an aftermarket one too?
Old Nov 15, 2003 | 03:57 PM
Default Re: dammit. timing belt snapped during freeway (dankbudz11357)
h23 for me though.. different belt than the h22 casue the head is taller
Old Nov 15, 2003 | 04:00 PM
dont mean to jack the thread...
how old was your belt? are u pushing some power? do u have aftermarket cam gears?
my aem gears were defective twice which messed mine up.. wish i still had pics.. the gear discentigrated and ripped the belt to shreads
Old Nov 15, 2003 | 04:28 PM
Tb Fivel's Avatar
toda doesnt make **** for h series motors. PE makes a nice belt, but i dont recomend spending the money on the belt until you find the reason for snapping your old belt. does it look worn on one side of the belt as if it were trying to run itelf off the gears or into the head? is it a clean pop? did you find any rocks or the like in the timing cover? do you even run a timing cover? all of these questions need to be adressed,. once you figure out why it popped weather it be a faulty timing belt or a rock, and you fix the problem, then i recomend buying yourself a power enterprise belt.
Old Nov 15, 2003 | 06:26 PM
satan_srv's Avatar
Default Re: dammit. timing belt snapped during freeway (Tb Fivel)
PE belt
Old Nov 15, 2003 | 09:34 PM
IloveNewt's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoostedH23a1 &raquo;</TD></TR><TR><TD CLASS="quote">yea miines snaped 3-4 times now... whenever they make a nice aftermarket one.. ill buy it</TD></TR></TABLE>
Because of your cam gears right? That is rediculous. Have you bent valves?
Makin me scuuured especially with my Portflow head with dual valvesprings......
Old Nov 15, 2003 | 09:35 PM
IloveNewt's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoostedH23a1 &raquo;</TD></TR><TR><TD CLASS="quote">h23 for me though.. different belt than the h22 casue the head is taller</TD></TR></TABLE>
Yea, wheres the love for the h23's?
Old Nov 15, 2003 | 11:43 PM
boon's Avatar
greddy makes timing belts too.
http://www.jdmhondaparts.com
its under engine products/mechanical related/
greddy timing belt for $150 h22.
Old Nov 16, 2003 | 03:57 PM
SKDRCR's Avatar
Default Re: (boon)
is the valvetrain stock.
dam son, 80 and 5 a mi. is highway robbery for a tow
Old Nov 16, 2003 | 04:37 PM
judonoh's Avatar
if you tightened the belt too much it will cause premature failure. Sorry to read about that, hope it doesn't cost a arm and leg to fix.
Old Nov 16, 2003 | 07:35 PM
HKSpowers's Avatar
going onto a freeway you must of been travelling at a decnetly high speed, timing belts snapping. I bet you must of bent a few valves my friend.
Sorry to say, timming belts snappinga t high speeds is cause for a head rebuilding, and even worse if youve damaged your crank because to your belt snapping.
Good Luck, i got my fingers crossed for you!
Old Nov 17, 2003 | 09:57 AM
F120man's Avatar
New User
Default Re: (judonoh)
really tho? cause i have a auto tensioner and can the auto tensioner tighten too much? welll right now i too off the belt and dropped the motor a bit to work under the car. the belt was ripped in half the long way. how do i check for bent valves or a bad valve train? is it recommended to buy new springs and valves w/ retainers for my head? i dont plan to get high lift cams or anythin, i was planning to squeeze some nitrious instead.
adeline
Feb 10, 2011 06:32 PM
M7EG6
10
Dec 5, 2008 08:45 PM
Rory Breaker
Dec 29, 2004 08:38 PM
N~FaMouSKhMerBoi
Jul 3, 2003 02:55 PM
