how do I replace the cv boot next to the rotor.
Old Nov 15, 2003 | 12:15 AM
Trbospnkr's Avatar
Default how do I replace the cv boot next to the rotor.
Grease is leaking out of it. I cannot remove the second joint next to the rotors
Old Nov 15, 2003 | 12:59 AM
dohcnotec's Avatar
Default Re: how do I replace the cv boot next to the rotor. (Trbospnkr)
I believe you are referring to the wheel side and not the tranny side. Anyway, get a punch (available at auto store/walmart $5/set) and a heavy mallet. Stick the center puch in the little divet in the middle of the axle (where the axle nut goes), and knock the **** out of it. A big hammer/mallet and persistance will have it out in less than 5 mins. If you're pecking at it with a household hammer, good luck.
Old Nov 15, 2003 | 01:07 AM
EFb18b's Avatar
Default Re: how do I replace the cv boot next to the rotor. (dohcnotec)
or you could just do what I did. Screw the axle nut flat on the threads and 1 hit with a 30 pound sledge will get it out. BTW most rebuilt axles come with a brand new axle nut so I wouldn't worry about messing it up
1990IntegraLS
Suspension & Brakes
May 19, 2018 01:09 PM
aowpsycho
Aug 30, 2009 07:11 PM
Mr. Giggles
Jan 23, 2007 06:15 PM
average_psi
Nov 8, 2004 08:45 AM
TeginRAGE
Jul 17, 2001 06:17 AM
