B18C1/C5
From: You can be my wingman anytime...., Las Vegas, US
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integra707 »</TD></TR><TR><TD CLASS="quote">Turn your Caps Lock off (click here).</TD></TR></TABLE>
LOL
I'll be nice this time.... in a nutshell, the blocks are virtually the same, but the internals are stronger in the C5. Balanced and polished crank, stronger/lighter rods, coated pistons, etc set it apart from the GSR's components. The heads are what really set the two apart. The C5's head uses a single runner IM, where the GSR's is dual runner and has the secondaries that open @ 5800. The C5's has a mild port job, larger T/B, and won't bolt up to the GSR head. The C5's head also has a factory port job, lightweight valves, stiffer valvesprings, and more powerful cams. Think of the C5 as a built GSR motor using all Honda factory parts.
LOL
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SLOAZZ94 »</TD></TR><TR><TD CLASS="quote">WHAT IS THE DIFFERENCE BETWEEN THESE 2 MOTORS
lol
lol
lol
damn talk about newbs
lol
</TD></TR></TABLE>ABOUT 20 HORSEPOWER, YOU CAN SQUEEZE OUT 25 IF YOU LEAVE THE CAPS LOCK ON
See this is why noone wants to post here and goes to all the other honda forums, because when a simple question is asked the all u fu***** as****** got to add some queer comment just to get your post total up. if u arn't answering the simple ???? then dont fu***** type on my post!!!!!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Gatecrasher19AF »</TD></TR><TR><TD CLASS="quote">Despite popular rumors and myths, there is no difference. They only have a different name to differentiate which one goes in an ITR and GS-R.</TD></TR></TABLE>
Ermm.. I smell false information.
This is a good explanation:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dr.FeelgooDC2 »</TD></TR><TR><TD CLASS="quote">
LOL
I'll be nice this time.... in a nutshell, the blocks are virtually the same, but the internals are stronger in the C5. Balanced and polished crank, stronger/lighter rods, coated pistons, etc set it apart from the GSR's components. The heads are what really set the two apart. The C5's head uses a single runner IM, where the GSR's is dual runner and has the secondaries that open @ 5800. The C5's has a mild port job, larger T/B, and won't bolt up to the GSR head. The C5's head also has a factory port job, lightweight valves, stiffer valvesprings, and more powerful cams. Think of the C5 as a built GSR motor using all Honda factory parts. </TD></TR></TABLE>
Cheers
LOL
Cheers
