What would you guys choose? Koni's with springs or Tein Basics?
Old Nov 14, 2003 | 10:27 AM
Honda Bob's Avatar
Default What would you guys choose? Koni's with springs or Tein Basics?
Ok, given that these are your only two options, what would you guys choose? Koni shocks with a good spring combo or Tein Basic coilovers?
Thanks
Old Nov 14, 2003 | 10:37 AM
King Tut33's Avatar
Default Re: What would you guys choose? Koni's with springs or Tein Basics? (Honda Bob)
MMMmmm Tein Basics. I know I did. Love the Tein quality and the adjustable ride height.
Matt B's Avatar
Konis with springs.
Old Nov 14, 2003 | 10:38 AM
2000blackgsr's Avatar
Default Re: What would you guys choose? Koni's with springs or Tein Basics? (Matt B)
I got the Koni's with springs (aka H&R cup kit)
Old Nov 14, 2003 | 10:39 AM
TOYsOTA's Avatar
in the same boat. koni yellows and h&r springs, or tein basics? or would the cost for better be justified?
Old Nov 14, 2003 | 10:40 AM
SkyeC's Avatar
Boba Connoisseur
25 Year Member
Koni's with H&R Race if you're going to race your car.
Basics if you're just a cruiser.
Old Nov 14, 2003 | 10:47 AM
VX's Avatar
VX
Default Re: What would you guys choose? Koni's with springs or Tein Basics? (SkyeC)
Koni Yellows + Ground-Control threaded coil-over sleeves + Eibach ERS custom springs.
Old Nov 14, 2003 | 11:34 AM
zanthrax's Avatar
I got Red koni's with Vogtland springs.
I am not going to sayi that Tein is bad.
But I went for a suspension-upgrade.
Mounting coilovers without mounting different shock isn't improving your suspension, it's just lowering your car. You could even make you suspension worse by dropping +1" on stock shocks. especially without adjusting for camber.
Old Nov 14, 2003 | 12:09 PM
SkyeC's Avatar
Boba Connoisseur
25 Year Member
Default Re: (zanthrax)
I know you're from some other country and all but don't post up about what you have no clue about.
TEIN Basics are Tein non-adjustable shocks, threaded sleeves, and springs. Entry-level system good for cruising but not-so-great for racing.
Old Nov 14, 2003 | 12:17 PM
BROOD's Avatar
Default Re: What would you guys choose? Koni's with springs or Tein Basics? (VX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VX &raquo;</TD></TR><TR><TD CLASS="quote">Koni Yellows + Ground-Control threaded coil-over sleeves + Eibach ERS custom springs.</TD></TR></TABLE>
I'll second this suggestion.
Koni Yellows (Neuspeed spec) + Ground-Control threaded coil-over sleeves + Eibach ERS custom springs
The Teins are nice but I would rather have the adjustable Konis. But if your set on having Teins I would just save up for SS versions.
Old Nov 15, 2003 | 11:35 AM
King Tut33's Avatar
Default Re: What would you guys choose? Koni's with springs or Tein Basics? (BROOD)
So how many of you guys with the adjustable shocks actually adjust them and actually auto-X your car?
Old Nov 15, 2003 | 11:54 AM
Eee Pee's Avatar
Default Re: What would you guys choose? Koni's with springs or Tein Basics? (King Tut33)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by King Tut33 &raquo;</TD></TR><TR><TD CLASS="quote">So how many of you guys with the adjustable shocks actually adjust them and actually auto-X your car?</TD></TR></TABLE>
I do.
And recommend adjustables. No matter who makes them.
Different situations need different settings.
Old Nov 15, 2003 | 12:22 PM
spraa's Avatar
From: Henderson/ College Station, Texas, United States
you should just go with koni yellows and ground controls with custom spring rates. that's all you will need great quality and rebuildable
Old Nov 15, 2003 | 12:51 PM
FifthGearOnline's Avatar
Default Re: (spraa)
Tein SS's
talk to vtecvoodoo
Old Nov 15, 2003 | 01:27 PM
SkyeC's Avatar
Boba Connoisseur
25 Year Member
you mean how many people with expensive green coilovers do more than photoshoots?
Old Nov 15, 2003 | 01:45 PM
i do more then photoshoots with my expensive green coilovers
Old Nov 15, 2003 | 01:46 PM
soundbomber's Avatar
Don't get tein. Way too BLING, for a fraction of the price, you could get a setup that outperforms the tein's. Koni yellows with custom gc springs with their extended top hats would be a great setup. Check it out!
Old Nov 15, 2003 | 03:27 PM
King Tut33's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SkyeC &raquo;</TD></TR><TR><TD CLASS="quote">
you mean how many people with expensive green coilovers do more than photoshoots? </TD></TR></TABLE>
No, the question was should he get Koni Yellow's with shock adjustability and no ride height adjustability or Tein Basics with no shock adjustability, just ride height adjustability. I don't plan on ever seriously racing mine, so I went with the Tein Basics for a decent ride and high quality. I just wanted to know how many Koni Yellow guys actually adjust their shocks.
Old Nov 15, 2003 | 05:06 PM
VX's Avatar
VX
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by King Tut33 &raquo;</TD></TR><TR><TD CLASS="quote">Koni Yellow's with shock adjustability and no ride height adjustability.</TD></TR></TABLE>
Koni Yellows + Coil-over Sleeves (Ground-Control) = Ride Height Adjustable.
On the shock body are grooves which a clip can be transfered onto any of them where the threaded coil-over sleeve sits.
This is the main height adjustment feature.
The second way is to adjust the spring perch up or down the threaded sleeves.
Old Nov 15, 2003 | 07:46 PM
SkyeC's Avatar
Boba Connoisseur
25 Year Member
No, the question was should he get Koni Yellow's with shock adjustability and no ride height adjustability or Tein Basics with no shock adjustability, just ride height adjustability. I don't plan on ever seriously racing mine, so I went with the Tein Basics for a decent ride and high quality. I just wanted to know how many Koni Yellow guys actually adjust their shocks.</TD></TR></TABLE>
So Koni's are low quality? lol.
Old Nov 15, 2003 | 07:50 PM
kikiboi's Avatar
get the teins, and you can brag about them being jdm (hehe).
side note(my personal opinion): since tein is such a big name here now in the states, and that many shops now carry them i feel like they lost some of their jdm sence of pride, you can say.
you can save up for some zeal shocks, or mugen full suspension coil-overs, those both would be yummy.
Old Nov 16, 2003 | 06:08 AM
King Tut33's Avatar
The second way is to adjust the spring perch up or down the threaded sleeves.</TD></TR></TABLE>
You didn't read his post, "Koni shocks with a good spring combo ". He didn't mention coilovers.
Old Nov 16, 2003 | 06:09 AM
King Tut33's Avatar
So Koni's are low quality? lol.</TD></TR></TABLE>
No Koni's are great, that is why everyone uses them. I just wanted a perfectly matched setup so I wouldn't have to worry about adjusting them, which is why I went with everything in one package, the Tein Basics.
Old Nov 16, 2003 | 06:13 AM
Navid OG's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SkyeC &raquo;</TD></TR><TR><TD CLASS="quote">Koni's with H&R Race if you're going to race your car.
thats what i got
Old Nov 16, 2003 | 06:18 AM
slammed_93_hatch's Avatar
Default Re: What would you guys choose? Koni's with springs or Tein Basics? (Navid OG)
koni's with the Grod control sleve for them,
tein basic's are just good for nice ride, thats it i rode in a car with them and it road great handeled shitty.
with koni/GC you get to pick any spring rate you want and any ride height you want from 0-5 inchs and it will be around 600 so saves you a few bucks too
