WTF is code 20 in PW0 b16 crx dual point to multi port conversion
Old Nov 14, 2003 | 09:28 AM
93LSivic's Avatar
Default WTF is code 20 in PW0 b16 crx dual point to multi port conversion
Totally baffled on what this code is. Someone says to check engine grounds.....they all look good. I need to finish this job today and get it out the door.
Any advice in appreciated!
Old Nov 14, 2003 | 12:57 PM
wickedEFguy's Avatar
Default Re: WTF is code 20 in PW0 b16 crx dual point to multi port conversion (93LSivic)
it's your ELD (electronic load detector)
here's a diagram that should help you
Old Nov 14, 2003 | 01:42 PM
93LSivic's Avatar
Default Re: WTF is code 20 in PW0 b16 crx dual point to multi port conversion (wicked B16)
What about on step 5 where you check at the green/red wire. Pin b19 where its home once was on the D motor is now home to the knock sensor for pw0/pr3.
Does anyone know if b14 which goes out to the alternator supposedly is to be wired to the green/red?
Touge Tuning
Jul 11, 2016 06:18 PM
integra_mike
Mar 9, 2007 09:02 AM
done
Oct 8, 2002 03:37 PM
hybrid901
May 1, 2002 12:59 PM
